call dynamic blocks from another file by autolisp
Hi guys, i am working in autolisp and i need to instantiate dynamic blocks that are in file "BLOQUES DINAMICOS 1.dwg" and put them in new file "prueba.dwg", i have to do this with autolisp in visual LISP.
There are some dynamic blocks (figures with blue color) in image, for example, the name of the second figure is "DIM.conexion mt y bt", i would like to put this in "prueba.dwg". I thank the person who can help me.
If you make a library of all your most used blocks its simple you can just insert that dwg/block straight in and update the dynamic attributes. Use wblock to pull the block out of the other dwg and save add to a block library area. You can use Tool Palette as well but its not something I have not used others will advise.
It is possible to export out all your as individual dwgs from a dwg. Just google.
The other way is to use lee-mac Steal.lsp you can drive this from a lisp program supplying dwg name and block name.
Edited by BIGAL
