jeffl Posted January 22, 2019 Share Posted January 22, 2019 I've created a lsp routine which creates a table and in one column I need to apply a fill color (background fill) to the cell. I have the color which should be applied to the cell. Currently it's just inserting the stored value in the format of 14 0 81 10485632, so the color I want to assign to the cell would be 81 (3rd value from left). This is what the table looks like, so it would be for column 0 I have everything else working great, just cant figure out how to change this so it fills with a color instead of populating it with the actual stored value. Here's the snippet of code which is used to fill columns 0,1,2 (setq rsid (AfmRsOpen SQLQuery)) ; Open record set for primary owner (while (not (AfmRsEOF rsid)) ; start loop for primary owner data (setq HpAcad (AfmRsGetStr rsid 0)) (setq buCode (AfmRsGetStr rsid 1)) (setq BuName (AfmRsGetStr rsid 2)) (setq lstOfSublist (list (list HpAcad buCode BuName ))) (foreach lstSublist lstOfSublist (foreach strItem lstSublist (vla-settext objtable intRow intColumn strItem) (setq intColumn (1+ intColumn)) ) ) The field is populated with HpAcad from above. I'll also post the actual file, this is my first attempt at using tables and I'm not much of a lsp writer to start with, so please excuse formatting for those detail oriented folks. Also please understand that you cant test the code do the system this was written for is specific to this application. Thanks HighxOwner.lsp Quote Link to comment Share on other sites More sharing options...
dlanorh Posted January 22, 2019 Share Posted January 22, 2019 It would appear that you are setting the cell text to the color value You need to use the SetCellbackgroundColor method either (vla-setcellbackgroundcolor table_obj row col color) or (vlax-invoke-method table_obj 'setcellbackgroundcolor row col color) This may involve having to get the correct AutoCAD Color Interface Object for your version Example Method Page Google 1 Quote Link to comment Share on other sites More sharing options...
jeffl Posted January 29, 2019 Author Share Posted January 29, 2019 On 1/22/2019 at 3:01 PM, dlanorh said: either (vla-setcellbackgroundcolor table_obj row col color) or (vlax-invoke-method table_obj 'setcellbackgroundcolor row col color) Thanks dlanorh, I'll give this a try. Sorry for the late response I only work on this on this once a week. Quote Link to comment Share on other sites More sharing options...
jeffl Posted February 5, 2019 Author Share Posted February 5, 2019 OK, so I've tried numerous ways to accomplish this with no success. What am I doing wrong in setting the color. So I'm passing in a color number in the strItem (lets call it 30) but it's not recognizing the value: (setq rsid (AfmRsOpen SQLQuery)) ; Open record set for primary owner (while (not (AfmRsEOF rsid)) ; start loop for primary owner data (setq HpAcad (AfmRsGetStr rsid 0)) (setq buCode (AfmRsGetStr rsid 1)) (setq BuName (AfmRsGetStr rsid 2)) (setq listResult (AfmHighlightSupStrToList HpAcad)) (setq strRet (nth 2 listResult)) ;(print strRet) (setq lstOfSublist (list (list strRet ))) (foreach lstSublist lstOfSublist (foreach strItem lstSublist (setq clr (vlax-create-object "AutoCAD.AcCmColor")) (vla-put-colorindex clr strItem) (vla-SetCellBackgroundColor objtable intRow intColumn clr) ;(vla-settext objtable intRow intColumn strItem) ;(setq intColumn (1+ intColumn)) ) ) If if I hard corded the value ( (vla-put-colorindex clr 30) I still get this error: error: bad argument type: VLA-OBJECT nil. I'm new to this so a little frustrating to say the least. Thanks Quote Link to comment Share on other sites More sharing options...
jeffl Posted February 5, 2019 Author Share Posted February 5, 2019 Also if I put the variable into the SetCellBackgroundColor (vla-SetCellBackgroundColor objtable intRow intColumn strItem) I get this error: error: lisp value has no coercion to VARIANT with this type: "30" Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted February 5, 2019 Share Posted February 5, 2019 (edited) Here is a quick example to point you in the right direction - (defun c:setcellcolour ( / acm col obj row sel ) (cond ( (not (and (princ "\nSelect table: ") (setq sel (ssget "_+.:E:S:L" '((0 . "ACAD_TABLE")))) (setq col (acad_colordlg 1 nil)) ) ) ) ( (not (setq acm (vla-getinterfaceobject (vlax-get-acad-object) (strcat "autocad.accmcolor." (substr (getvar 'acadver) 1 2)) ) ) ) (princ "\nUnable to interface with AcCmColor object.") ) ( (setq obj (vlax-ename->vla-object (ssname sel 0))) (vla-put-colorindex acm col) (vla-put-regeneratetablesuppressed obj :vlax-true) (repeat (setq row (vla-get-rows obj)) (setq row (1- row)) (repeat (setq col (vla-get-columns obj)) (vla-setcellbackgroundcolor obj row (setq col (1- col)) acm) ) ) (vla-put-regeneratetablesuppressed obj :vlax-false) (vlax-release-object acm) ) ) (princ) ) (vl-load-com) (princ) Edited February 5, 2019 by Lee Mac Quote Link to comment Share on other sites More sharing options...
jeffl Posted February 5, 2019 Author Share Posted February 5, 2019 Thanks Lee, I'll see what I can decipher from this. Quote Link to comment Share on other sites More sharing options...
Grrr Posted February 5, 2019 Share Posted February 5, 2019 Hi Lee, I remember your post from here about obtaining the AcCmColor object, then in this case would it behave in the same way - (setq acm (vla-get-TrueColor (vlax-ename->vla-object (ssname sel 0)))) Instead of creating an instance of it, like its normally accepted - (setq acm (vla-getinterfaceobject (vlax-get-acad-object) (strcat "autocad.accmcolor." (substr (getvar 'acadver) 1 2)) ) ) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted February 5, 2019 Share Posted February 5, 2019 1 minute ago, Grrr said: I remember your post from here about obtaining the AcCmColor object, then in this case would it behave in the same way... Indeed, that's also an alternative 1 Quote Link to comment Share on other sites More sharing options...
jeffl Posted February 12, 2019 Author Share Posted February 12, 2019 (edited) I think you gentlemen for the responses, I have everything working now. Really appreciate the assistance which you provided. Edited February 12, 2019 by jeffl Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted February 12, 2019 Share Posted February 12, 2019 You're welcome Jeff Quote Link to comment Share on other sites More sharing options...
