what I'm trying to do is, Check if there any (not found, or not resolved Xref's Proceed to Bind) If their Xrefs need to reload (Reload them) and then Bind all resolved Xrefs.
ObjectIdCollection btrCol = new ObjectIdCollection();
                    XrefGraph xrgraph = doc.Database.GetHostDwgXrefGraph(false);
                    db.ResolveXrefs(true, false);
                    for (int i = 1; i < (xrgraph.NumNodes); i++)
                        XrefGraphNode xrNode = xrgraph.GetXrefNode(i);
                        switch (xrNode.XrefStatus)
                            case XrefStatus.Resolved:
                                btrCol.Add(xrNode.BlockTableRecordId);
                                break;
                            case XrefStatus.Unloaded:
                                break;
                            case XrefStatus.FileNotFound:
                                break;
                            case XrefStatus.NotAnXref:
                                break;
                            case XrefStatus.Unreferenced:
                                break;
                    try
                        if (btrCol.Count > 0)
                            db.ReloadXrefs(btrCol);
                            db.BindXrefs(btrCol, true);
In debug mode, the code going well and I check the ObjectIdCollection,
 and it contains the target Xrefs and voids the (unresolved) Xref's as I need. But not Bind or Reload.
the conclusion is:
I need the code to Reload all Xref's need to reload. then Bind all. regardless any Xref's (Not Found, Not an Xref, etc...)
as the attached lisp.
(defun c:bindloaded(/ cObj cName)
  (setq cObj(tblnext "BLOCK" T))
  (while cObj
    (setq cName(cdr(assoc 2 cObj)))
    (if
      (and
	 (=(logand(cdr(assoc 70 cObj))32)32)
	 (=(logand(cdr(assoc 70 cObj))4)4)
	 ); end and
       (vl-cmdf "bindtype" "1")
       (vl-cmdf "_.xref" "_unload" cName)
       (vl-cmdf "_.xref" "_reload" cName)
       (vl-cmdf "_.xref" "_bind" cName)
       ); end progn
      ); wnd if
  (setq cObj(tblnext "BLOCK"))
  ); end while
  ); end of c:bindloaded
thanks in advance.
