  On 1/16/2019 at 8:26 PM, dlanorh said:
(defun c:LPV ( / ent ll ur m_pt last_v e_pt s_pt t_ht cnt v_pt)
  (cond ( (and  (setq ent (car (entsel "\nSelect Polyline to Label : ")))
                (= (cdr (assoc 0 (entget ent))) "LWPOLYLINE")
          );end_and
          (vla-getboundingbox (vlax-ename->vla-object ent) 'll 'ur)
          (setq m_pt (mapcar '(lambda (x y) (/ (+ x y) 2.0)) (vlax-safearray->list ll)  (vlax-safearray->list ur))
                last_v (vlax-curve-getendparam ent)
                e_pt (vlax-curve-getendpoint ent)
                s_pt (vlax-curve-getstartpoint ent)
                t_ht (getvar 'textsize)
                t_fact 1.1
                cnt 0.0
          );end_setq
          (if (equal e_pt s_pt 0.001) (setq last_v (1- last_v)))
          (while (<= cnt last_v)
            (setq v_pt (vlax-curve-getpointatparam ent cnt))
            (entmakex (list
                          (cons 0 "TEXT")
                          (cons 7 (getvar 'textstyle))
                          (cons 40 t_ht)
                          (cons 10 (polar m_pt (angle m_pt v_pt) (+ (* t_ht t_fact) (distance m_pt v_pt))))
                          (cons 11 (polar m_pt (angle m_pt v_pt) (+ (* t_ht t_fact) (distance m_pt v_pt))))
                          (cons 1 (chr (+ 65 (fix cnt))))
                          (cons 72 1)
                          (cons 73 2)
                      );end_list
            );end_entmakex
           (setq cnt (1+ cnt))
          );end_while
        ( (alert "Not a Polyline"))
  );end_cond
);end_defun
Expand
The script works fine, but  I need a modified version.
I need these features:
- At every vertex create a POINT entity;
- Instead of A..B..C labeling, I need to insert a number, like 1..2..3, but first number should be read from keyboard. So, if I enter 5 as first number, it should increment like 5..6..7..8..... every vertex of polyline.
Can someone modify the script, please? Thank you.
Here you are, Sir!
Welcome in the forum, Ttee77!  :)
          );end_and
                t_fact 1.1
                cnt 0.0
          );end_set
	 (setq i1 (getint "Starting number?") i1 (1- i1))
            (entmakex (list
                          (cons 0 "TEXT")
                          (cons 40 t_ht)
			  ;(cons 1 (chr (+ 65 (fix cnt))))
                          (cons 1 (itoa (setq i1 (1+ i1)))) ;changed chr to integer
                          (cons 72 1)
                          (cons 73 2)
                      );end_list
            );end_entmakex
           (setq cnt (1+ cnt))
          );end_while
  );end_cond
);end_defun
Ops! I forgot about the point!
See here a shorter version. It will put a point and it will add a number as you asked:
(defun c:pp()
  (setq pl (entget (car (entsel "Select polyline"))))
  (setq n (1- (getint "\nStarting number? ")))
  (while pl
    (setq pl (member (assoc 10 pl) pl))
    (setq a10 (car pl) pl (cdr pl))
    (entmake (list '(0 . "POINT") a10))
    (entmake (list '(0 . "TEXT") (cons 1 (itoa (setq n (1+ n)))) a10 (cons 40 (getvar "TEXTSIZE"))))
