Janax Posted January 14, 2019 Share Posted January 14, 2019 Hello everyone. I am looking for a way to cut down time on redrawing bend lines (marking for laser ). I need to draw marking lines by selecting entity or two points between line with offset "H" from begining and end and length "L" . Quote Link to comment Share on other sites More sharing options...
SLW210 Posted January 14, 2019 Share Posted January 14, 2019 I have moved your thread to the AutoLISP, Visual LISP & DCL Forum. Quote Link to comment Share on other sites More sharing options...
David Bethel Posted January 14, 2019 Share Posted January 14, 2019 Assuming you are dealing with 2D LINE entities only, this could work (defun c:bendl (/ h l ss i en ed p10 p11) (or gv_offset (setq gv_offset 1)) (initget 6) (setq h (getdist (strcat "\nOffset Distance <" (rtos gv_offset 2 2) ">: "))) (or h (setq h gv_offset)) (setq gv_offset h) (or gv_length (setq gv_length 1)) (initget 6) (setq l (getdist (strcat "\nLength Distance <" (rtos gv_length 2 2) ">: "))) (or l (setq l gv_length)) (setq gv_length l) (while (setq ss (ssget (list (cons 0 "LINE")))) (setq i 0) (while (setq en (ssname ss i)) (setq ed (entget en) p10 (cdr (assoc 10 ed)) p11 (cdr (assoc 11 ed))) (entmake (list (cons 0 "LINE") (assoc 8 ed) (cons 62 1) (cons 10 (polar p10 (angle p10 p11) h)) (cons 11 (polar p10 (angle p10 p11) (+ h l))))) (entmake (list (cons 0 "LINE") (cons 62 1) (cons 10 (polar p11 (angle p11 p10) h)) (cons 11 (polar p11 (angle p11 p10) (+ h l))))) (setq i (1+ i)))) (prin1)) -David 1 Quote Link to comment Share on other sites More sharing options...
Janax Posted January 14, 2019 Author Share Posted January 14, 2019 Thank you David. You saved me alot of time Quote Link to comment Share on other sites More sharing options...
David Bethel Posted January 14, 2019 Share Posted January 14, 2019 You're welcome. You could customize this into a lot of things. -David Quote Link to comment Share on other sites More sharing options...
