asra Posted October 18, 2019 Share Posted October 18, 2019 thaks @leemac to you response, but i dont understand, cause im newbie so which code do you think should be changed or added? (defun c:test ( / ent ss cnt e_lst i_pt c_pt) (setq ent (car (entsel "\nSelect Line Entity : "))) (cond ( (vl-position (cdr (assoc 0 (entget ent))) '("LWPOLYLINE" "ARC" "LINE" "CIRCLE" "ELLIPSE" "SPLINE")) (prompt "\nSelect Points : ") (setq ss (ssget '((0 . "POINT,TEXT")))) (repeat (setq cnt (sslength ss)) (setq i_pt (cdr (assoc 10 (setq e_lst (entget (ssname ss (setq cnt (1- cnt))))))) c_pt (vlax-curve-getclosestpointto ent i_pt) ) (entmod (subst (cons 10 c_pt) (assoc 10 e_lst) e_lst)) );end_repeat ) ( (alert "Not a Line Entity")) );end_cond (princ) );end_defun Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 18, 2019 Share Posted October 18, 2019 Un tested but change this line c_pt (vlax-curve-getclosestpointto ent i_pt) 1 Quote Link to comment Share on other sites More sharing options...
asra Posted October 20, 2019 Share Posted October 20, 2019 hi @BIGAL replaced by what? Quote Link to comment Share on other sites More sharing options...
dlanorh Posted October 20, 2019 Share Posted October 20, 2019 c_pt (vlax-curve-getclosestpointto ent i_pt) c_pt (vlax-curve-getclosestpointtoprojection ent i_pt) Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted October 20, 2019 Share Posted October 20, 2019 No, dlanorh... It should be : c_pt (vlax-curve-getclosestpointto ent i_pt) c_pt (append (mapcar '+ '(0 0) (vlax-curve-getclosestpointto ent i_pt)) (list (caddr i_pt))) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 20, 2019 Share Posted October 20, 2019 On 10/17/2019 at 1:06 PM, Lee Mac said: Hint: use the vlax-curve-getclosestpointtoprojection function instead, for reasons I describe here. This is the method I was suggesting - (defun c:test ( / e i p q s x ) (if (and (setq s (ssget "_:L" '((0 . "POINT")))) (progn (while (progn (setvar 'errno 0) (setq e (entsel)) (cond ( (= 7 (getvar 'errno)) (princ "\nMissed, try again.") ) ( (null e) nil) ( (vl-catch-all-error-p (vl-catch-all-apply 'vlax-curve-getclosestpointto e)) (princ "\nInvalid object selected.") ) ) ) ) (setq e (car e)) ) ) (repeat (setq i (sslength s)) (setq i (1- i) x (entget (ssname s i)) p (assoc 10 x) q (vlax-curve-getclosestpointtoprojection e (list (cadr p) (caddr p)) '(0 0 1)) ) (entmod (subst (list 10 (car q) (cadr q) (cadddr p)) p x)) ) ) (princ) ) (vl-load-com) (princ) This accounts for points & curve objects residing at different elevations, with the closest point calculated in the WCS plane. Quote Link to comment Share on other sites More sharing options...
