joemcanciller Posted January 4, 2019 Posted January 4, 2019 Hi guys, Im looking for lisp routine that instantly inserts field for measurement of dimension line to an attribute text or specific attribute tag in a block. i.e. I have this dimension line "dim A" and a tag "cutting_length" in the attribute, such that the attribute value will change according to the dimension. Thanks in advance! Quote
Emmanuel Delay Posted January 4, 2019 Posted January 4, 2019 (edited) (attribute definition) cutting_length is inside a block, right? Is dimension line "dim A" part of the block? maybe a dynamic block? If the dimension is just a loose dimension, try this (command DTA, for dim to attribute): ;; Set Attribute Value - Lee Mac ;; Sets the value of the first attribute with the given tag found within the block, if present. ;; blk - [ent] Block (Insert) Entity Name ;; tag - [str] Attribute TagString ;; val - [str] Attribute Value ;; Returns: [str] Attribute value if successful, else nil. (defun LM:setattributevalue ( blk tag val / enx ) (if (and (setq blk (entnext blk)) (= "ATTRIB" (cdr (assoc 0 (setq enx (entget blk)))))) (if (= (strcase tag) (strcase (cdr (assoc 2 enx)))) (if (entmod (subst (cons 1 val) (assoc 1 (reverse enx)) enx)) (progn (entupd blk) val ) ) (LM:setattributevalue blk tag val) ) ) ) (defun c:dta ( / dim blk lng) (setq dim (entsel "\nSelect the dim")) (setq blk (entsel "\nSelect the block")) (setq lng (cdr (assoc 42 (entget (car dim))))) (LM:setattributevalue (car blk) "cutting_length" (rtos lng 2 3)) ;; that 3 is the precision. Feel free to change it (princ) ) attachment: the circle is a block called "B" with an attribute "cutting_length" dta.dwgFetching info... Edited January 4, 2019 by Emmanuel Delay 1 Quote
Lee Mac Posted January 4, 2019 Posted January 4, 2019 Assuming I've understood correctly, you could use my Length & Area Field program with the predetermined attribute tag argument. Download the program from the link provided. Open the program file in Windows Notepad or similar plain text editor. Copy the following to a new line at the start or end of the file: (defun c:cl ( ) (lengthfield "CUTTING_LENGTH" "%lu6")) Save the program file. Open AutoCAD. Load the program file using APPLOAD or other loading method. Run the custom command you have just defined using the syntax CL at the command-line. 1 Quote
joemcanciller Posted January 5, 2019 Author Posted January 5, 2019 On 1/4/2019 at 1:19 PM, Emmanuel Delay said: (attribute definition) cutting_length is inside a block, right? Is dimension line "dim A" part of the block? maybe a dynamic block? If the dimension is just a loose dimension, try this (command DTA, for dim to attribute): ;; Set Attribute Value - Lee Mac ;; Sets the value of the first attribute with the given tag found within the block, if present. ;; blk - [ent] Block (Insert) Entity Name ;; tag - [str] Attribute TagString ;; val - [str] Attribute Value ;; Returns: [str] Attribute value if successful, else nil. (defun LM:setattributevalue ( blk tag val / enx ) (if (and (setq blk (entnext blk)) (= "ATTRIB" (cdr (assoc 0 (setq enx (entget blk)))))) (if (= (strcase tag) (strcase (cdr (assoc 2 enx)))) (if (entmod (subst (cons 1 val) (assoc 1 (reverse enx)) enx)) (progn (entupd blk) val ) ) (LM:setattributevalue blk tag val) ) ) ) (defun c:dta ( / dim blk lng) (setq dim (entsel "\nSelect the dim")) (setq blk (entsel "\nSelect the block")) (setq lng (cdr (assoc 42 (entget (car dim))))) (LM:setattributevalue (car blk) "cutting_length" (rtos lng 2 3)) ;; that 3 is the precision. Feel free to change it (princ) ) attachment: the circle is a block called "B" with an attribute "cutting_length" dta.dwgFetching info... Expand Thanks bud. It works. The dimension reflects on the attribute value but the value doesn't change when the dimension changes even after regen. :O Quote
joemcanciller Posted January 5, 2019 Author Posted January 5, 2019 On 1/4/2019 at 7:15 PM, Lee Mac said: Assuming I've understood correctly, you could use my Length & Area Field program with the predetermined attribute tag argument. Download the program from the link provided. Open the program file in Windows Notepad or similar plain text editor. Copy the following to a new line at the start or end of the file: (defun c:cl ( ) (lengthfield "CUTTING_LENGTH" "%lu6")) Save the program file. Open AutoCAD. Load the program file using APPLOAD or other loading method. Run the custom command you have just defined using the syntax CL at the command-line. Expand thanks @Lee Mac. you're great. I missed this program while searching in your program lists. :D How do I include measurement of dimension line to the code because it only applies to length of objects? Thanks. :) Quote
Lee Mac Posted January 5, 2019 Posted January 5, 2019 On 1/5/2019 at 1:59 AM, joemcanciller said: @Lee Mac How do I include measurement of dimension line to the code because it only applies to length of objects? Expand Change the property list at line 109 from: (setq prp '( ("AcDbArc" . "ArcLength") ("AcDbCircle" . "Circumference") ("AcDbLine" . "Length") ("AcDbPolyline" . "Length") ("AcDb2dPolyline" . "Length") ("AcDb3dPolyline" . "Length") ) ) to: (setq prp '( ("AcDbArc" . "ArcLength") ("AcDbCircle" . "Circumference") ("AcDbLine" . "Length") ("AcDbPolyline" . "Length") ("AcDb2dPolyline" . "Length") ("AcDb3dPolyline" . "Length") ("AcDb2LineAngularDimension" . "Measurement") ("AcDbDiametricDimension" . "Measurement") ("AcDbRadialDimensionLarge" . "Measurement") ("AcDbRadialDimension" . "Measurement") ("AcDbOrdinateDimension" . "Measurement") ("AcDbRotatedDimension" . "Measurement") ("AcDbAlignedDimension" . "Measurement") ("AcDb3PointAngularDimension" . "Measurement") ("AcDbArcDimension" . "Measurement") ) ) And change the ssget filter list on line 125 from: '(000 . "ARC,CIRCLE,LINE,*POLYLINE") to: '(000 . "ARC,CIRCLE,LINE,*POLYLINE,*DIMENSION") Quote
joemcanciller Posted January 7, 2019 Author Posted January 7, 2019 On 1/5/2019 at 12:04 PM, Lee Mac said: Change the property list at line 109 from: (setq prp '( ("AcDbArc" . "ArcLength") ("AcDbCircle" . "Circumference") ("AcDbLine" . "Length") ("AcDbPolyline" . "Length") ("AcDb2dPolyline" . "Length") ("AcDb3dPolyline" . "Length") ) ) to: (setq prp '( ("AcDbArc" . "ArcLength") ("AcDbCircle" . "Circumference") ("AcDbLine" . "Length") ("AcDbPolyline" . "Length") ("AcDb2dPolyline" . "Length") ("AcDb3dPolyline" . "Length") ("AcDb2LineAngularDimension" . "Measurement") ("AcDbDiametricDimension" . "Measurement") ("AcDbRadialDimensionLarge" . "Measurement") ("AcDbRadialDimension" . "Measurement") ("AcDbOrdinateDimension" . "Measurement") ("AcDbRotatedDimension" . "Measurement") ("AcDbAlignedDimension" . "Measurement") ("AcDb3PointAngularDimension" . "Measurement") ("AcDbArcDimension" . "Measurement") ) ) And change the ssget filter list on line 125 from: '(000 . "ARC,CIRCLE,LINE,*POLYLINE") to: '(000 . "ARC,CIRCLE,LINE,*POLYLINE,*DIMENSION") Expand Thanks @Lee Mac. I'm learning a lot from you. :) Quote
Davide Posted February 23, 2020 Posted February 23, 2020 Hi to all, I was looking for this Lisp for a while: thank you for your wonderful work. Now a little help... I've make the change to the original Lisp of Lee Mac as above (with a different name for the Tag). Could please someone help me and make another change to the Lisp? I need to bypass the step "Specify point or table cell [Object eXit]" to have the possibility to select the object as default option? I need to put dimensions value in an attribute and I don't want every time to type the "O" for object. Cheers, D. HERE THE CODE WITH CHANGES: ;;----------------------------------------------------------------------;; ;; Length Field Commands ;; ;;----------------------------------------------------------------------;; (defun c:cl ( ) (lengthfield "MIS_1" "%lu6"));; CHANGE TAG NAME (defun c:lf ( ) (lengthfield nil "%lu6")) ;; Current units (defun c:lfm ( ) (lengthfield nil "%lu6%ct8[0.001]")) ;; Current units with 0.001 conversion factor (mm->m) ;;----------------------------------------------------------------------;; ;; Area Field Commands ;; ;;----------------------------------------------------------------------;; (defun c:af ( ) (areafield nil "%lu6%qf1")) ;; Current units (defun c:afm ( ) (areafield nil "%lu6%qf1%ct8[1e-6]")) ;; Current units with 1e-6 (0.000001) conversion factor (mm2->m2) ;;----------------------------------------------------------------------;; ;;----------------------=={ Length & Area Field }==---------------------;; ;; ;; ;; This program offers two commands to allow a user to generate a ;; ;; field expression referencing either the area or the ;; ;; length/perimeter/circumference of one or more selected objects. ;; ;; In the case of selecting multiple objects, the field expression ;; ;; will reference the sum of the areas or lengths of all objects in ;; ;; the selection. ;; ;; ;; ;; The user may opt to specify a point at which to create a new ;; ;; multiline text object housing the field expression, pick a table ;; ;; cell in which the field should be inserted, or select an existing ;; ;; single-line text, multiline text, multileader, or attribute to ;; ;; be populated with the field expression. ;; ;; ;; ;; Upon issuing the command syntax 'LF' (Length Field) at the AutoCAD ;; ;; command-line, the program first prompts the user to make a ;; ;; selection of objects for which to return the length summation. ;; ;; ;; ;; At this prompt, the user may select any number of Arcs, Circles, ;; ;; Lines, 2D Polylines (light or heavy), or 3D Polylines. ;; ;; ;; ;; Alternatively, upon issuing the command syntax 'AF' (Area Field) ;; ;; at the AutoCAD command-line, the program will prompt the user to ;; ;; make a selection of objects for which to return the area summation. ;; ;; ;; ;; At this prompt, the user may select any number of Arcs, Circles, ;; ;; Ellipses, Hatches, 2D Polylines (light or heavy), Regions, or ;; ;; Splines. If the selected object is open, the area is computed as ;; ;; though a straight line connects the start point and endpoint. ;; ;; ;; ;; The user is then prompted to specify a point or table cell to ;; ;; insert a field expression referencing the summation of the lengths ;; ;; or areas of the selected objects. ;; ;; ;; ;; At this prompt, the user may also choose the 'Object' option in ;; ;; order to populate the content of an existing annotation object ;; ;; with the field expression. ;; ;; ;; ;; Upon choosing this option, the user may select any single-line ;; ;; text (DText), multiline text (MText), single-line or multiline ;; ;; attribute, attributed block, or multileader (MLeader) with either ;; ;; multiline text or attributed block content. ;; ;; ;; ;; If the user selects an attributed block or attributed multileader ;; ;; with more than one attribute, the user is presented with a dialog ;; ;; interface listing the available attributes, and is prompted to ;; ;; select a destination for the field expression. ;; ;; ;; ;; The user may optionally predefine the target block/multileader ;; ;; attribute by specifying the attribute tag where noted at the top ;; ;; of the program source code. ;; ;; ;; ;; The resulting field expression will display the sum of the lengths ;; ;; or areas of the selected objects, formatted using the field ;; ;; formatting code specified at the top of each command definition. ;; ;; ;; ;;----------------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2017 - www.lee-mac.com ;; ;;----------------------------------------------------------------------;; ;; Version 1.0 - 2017-08-06 ;; ;; ;; ;; - First release. ;; ;;----------------------------------------------------------------------;; ;; Version 1.1 - 2017-08-06 ;; ;; ;; ;; - Program modified to account for selection of existing annotation ;; ;; objects which already contain a field expression. ;; ;;----------------------------------------------------------------------;; ;; Version 1.2 - 2018-10-29 ;; ;; ;; ;; - Restructured program to use standard LM:outputtext function. ;; ;; - Incorporated Area Field functionality and added new 'AF' command. ;; ;;----------------------------------------------------------------------;; ;; Version 1.3 - 2018-11-04 ;; ;; ;; ;; - Changed 'c:lf' and 'c:af' commands to functions accepting an ;; ;; optional attribute tag and field formatting argument to enable ;; ;; the user to create multiple commands with varying parameters. ;; ;;----------------------------------------------------------------------;; (defun lengthfield ( tag fmt / *error* idx lst obj prp sel ) (defun *error* ( msg ) (LM:endundo (LM:acdoc)) (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))) (princ (strcat "\nError: " msg)) ) (princ) ) (LM:startundo (LM:acdoc)) (setq prp '( ("AcDbArc" . "ArcLength") ("AcDbCircle" . "Circumference") ("AcDbLine" . "Length") ("AcDbPolyline" . "Length") ("AcDb2dPolyline" . "Length") ("AcDb3dPolyline" . "Length") ("AcDb2LineAngularDimension" . "Measurement") ("AcDbDiametricDimension" . "Measurement") ("AcDbRadialDimensionLarge" . "Measurement") ("AcDbRadialDimension" . "Measurement") ("AcDbOrdinateDimension" . "Measurement") ("AcDbRotatedDimension" . "Measurement") ("AcDbAlignedDimension" . "Measurement") ("AcDb3PointAngularDimension" . "Measurement") ("AcDbArcDimension" . "Measurement") ) ) (if (setq sel (LM:ssget "\nSelect objects to obtain total length <exit>: " (list (list '(000 . "ARC,CIRCLE,LINE,*POLYLINE,*DIMENSION") '(-04 . "<NOT") '(-04 . "<AND") '(000 . "POLYLINE") '(-04 . "&") '(070 . 80) '(-04 . "AND>") '(-04 . "NOT>") (if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model") ) ) ) ) ) (LM:outputtext tag (if (= 1 (sslength sel)) (progn (setq obj (vlax-ename->vla-object (ssname sel 0))) (strcat "%<\\AcObjProp Object(%<\\_ObjId " (LM:objectid obj) ">%)." (cdr (assoc (vla-get-objectname obj) prp)) (if (and fmt (/= "" fmt)) (strcat " \\f \"" fmt "\">%") ">%") ) ) (progn (repeat (setq idx (sslength sel)) (setq obj (vlax-ename->vla-object (ssname sel (setq idx (1- idx)))) lst (vl-list* "%<\\AcObjProp Object(%<\\_ObjId " (LM:objectid obj) ">%)." (cdr (assoc (vla-get-objectname obj) prp)) ">%" " + " lst ) ) ) (strcat "%<\\AcExpr " (apply 'strcat (reverse (cdr (reverse lst)))) (if (and fmt (/= "" fmt)) (strcat " \\f \"" fmt "\">%") ">%") ) ) ) ) ) (*error* nil) (princ) ) ;;----------------------------------------------------------------------;; (defun areafield ( tag fmt / *error* idx lst sel ) (defun *error* ( msg ) (LM:endundo (LM:acdoc)) (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))) (princ (strcat "\nError: " msg)) ) (princ) ) (LM:startundo (LM:acdoc)) (if (setq sel (LM:ssget "\nSelect objects to obtain total area <exit>: " (list (list '(000 . "ARC,CIRCLE,ELLIPSE,HATCH,*POLYLINE,REGION,SPLINE") '(-04 . "<NOT") '(-04 . "<AND") '(000 . "POLYLINE") '(-04 . "&") '(070 . 88) '(-04 . "AND>") '(-04 . "NOT>") (if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model") ) ) ) ) ) (LM:outputtext tag (if (= 1 (sslength sel)) (strcat "%<\\AcObjProp Object(%<\\_ObjId " (LM:objectid (vlax-ename->vla-object (ssname sel 0))) ">%).Area" (if (and fmt (/= "" fmt)) (strcat " \\f \"" fmt "\">%") ">%") ) (progn (repeat (setq idx (sslength sel)) (setq lst (vl-list* "%<\\AcObjProp Object(%<\\_ObjId " (LM:objectid (vlax-ename->vla-object (ssname sel (setq idx (1- idx))))) ">%).Area>%" " + " lst ) ) ) (strcat "%<\\AcExpr " (apply 'strcat (reverse (cdr (reverse lst)))) (if (and fmt (/= "" fmt)) (strcat " \\f \"" fmt "\">%") ">%") ) ) ) ) ) (*error* nil) (princ) ) ;; Output Text - Lee Mac ;; Prompts the user to specify a point at which to create an MText object containing the supplied string or to ;; select a table cell, text, mtext, multileader, attribute, or attributed block to be populated with the supplied string. ;; tag - [str] Optional target attribute tag ;; str - [str] Field expression or other text content (defun LM:outputtext ( tag str / ent enx flg idx obj oid sel tab tmp typ ) (if (setq tmp (ssget "_X" (list '(0 . "ACAD_TABLE") (if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model") ) ) ) ) (repeat (setq idx (sslength tmp)) (setq tab (cons (vlax-ename->vla-object (ssname tmp (setq idx (1- idx)))) tab)) ) ) (while (not (progn (if flg (progn (setvar 'errno 0) (initget "Point eXit") (setq sel (nentsel "\nSelect text, mtext, mleader, attribute or attributed block [Point/eXit] <eXit>: ")) ) (progn (initget "Object eXit") (setq sel (getpoint "\nSpecify point or table cell [Object/eXit] <eXit>: ")) ) ) (cond ( (= 7 (getvar 'errno)) (prompt "\nMissed, try again.") ) ( (or (null sel) (= "eXit" sel))) ( (= "Point" sel) (setq flg nil) ) ( (= "Object" sel) (not (setq flg t)) ) ( flg (setq ent (car sel) enx (entget ent) typ (cdr (assoc 0 enx)) obj (vlax-ename->vla-object ent) ) (cond ( (and (= 2 (length sel)) (wcmatch typ "TEXT,MTEXT")) (if (vlax-write-enabled-p obj) (LM:outputtext:puttextstring obj str) (prompt "\nThe selected text object is on a locked layer.") ) ) ( (and (= "ATTRIB" typ) (/= 'str (type tag)) ) (if (vlax-write-enabled-p obj) (progn (LM:outputtext:puttextstring obj str) (if (wcmatch (strcase str t) "*%<\\ac*>%*") (LM:outputtext:updatefield ent)) ) (prompt "\nThe selected attribute is on a locked layer.") ) ) ( (and (or (and (= "ATTRIB" typ) (setq tmp (cdr (assoc 330 enx))) ) (and (setq tmp (last (cadddr sel))) (= "INSERT" (cdr (assoc 0 (entget tmp)))) ) ) (setq tmp (vlax-invoke (vlax-ename->vla-object tmp) 'getattributes)) (or (and (= 'str (type tag)) (setq idx (vl-position (strcase tag) (mapcar 'vla-get-tagstring tmp))) (setq obj (nth idx tmp)) ) (and (not (cdr tmp)) (setq obj (car tmp)) ) (and (setq idx (LM:listbox "Choose Attribute" (mapcar 'vla-get-tagstring tmp) 2)) (setq obj (nth (car idx) tmp)) ) ) ) (if (vlax-write-enabled-p obj) (progn (LM:outputtext:puttextstring obj str) (if (wcmatch (strcase str t) "*%<\\ac*>%*") (LM:outputtext:updatefield (vlax-vla-object->ename obj))) ) (prompt "\nThe selected attribute is on a locked layer.") ) ) ( (and (= 2 (length sel)) (= "MULTILEADER" typ)) (setq typ (cdr (assoc 172 (reverse enx)))) (cond ( (and (<= acblockcontent typ acmtextcontent) (not (vlax-write-enabled-p obj))) (prompt "\nThe selected multileader is on a locked layer.") ) ( (= acmtextcontent typ) (LM:outputtext:puttextstring obj str) (if (wcmatch (strcase str t) "*%<\\ac*>%*") (vla-regen (LM:acdoc) acactiveviewport)) t ) ( (and (= acblockcontent typ) (setq tmp (LM:getmleaderattributes obj)) (or (and (= 'str (type tag)) (setq oid (cdr (assoc (strcase tag) tmp))) ) (and (not (cdr tmp)) (setq oid (cdar tmp)) ) (and (setq idx (LM:listbox "Choose Attribute" (mapcar 'car tmp) 2)) (setq oid (cdr (nth (car idx) tmp))) ) ) ) (LM:setmleaderattributevalue obj oid str) (if (wcmatch (strcase str t) "*%<\\ac*>%*") (vla-regen (LM:acdoc) acactiveviewport)) t ) ( (prompt "\nThe select multileader has no editable content.")) ) ) ( (prompt "\nThe selected object is not text, mtext, multileader, attribute or attributed block.")) ) ) ( (setq tmp (LM:getcell tab (trans sel 1 0))) (if (vlax-write-enabled-p (car tmp)) (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-settext (append tmp (list str))))) (prompt "\nThe selected table cell belongs to a table on a locked layer.") ) ) ( (vla-addmtext (vlax-get-property (LM:acdoc) (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace)) (vlax-3D-point (trans sel 1 0)) 0.0 str ) ) ) ) ) ) ) (defun LM:outputtext:puttextstring ( obj str ) (vla-put-textstring obj "") ;; To clear any existing field (vla-put-textstring obj str) t ) (defun LM:outputtext:updatefield ( ent / cmd rtn ) (setq cmd (getvar 'cmdecho)) (setvar 'cmdecho 0) (setq rtn (vl-cmdf "_.updatefield" ent "")) (setvar 'cmdecho cmd) rtn ) ;; ssget - Lee Mac ;; A wrapper for the ssget function to permit the use of a custom selection prompt ;; msg - [str] selection prompt ;; arg - [lst] list of ssget arguments (defun LM:ssget ( msg arg / sel ) (princ msg) (setvar 'nomutt 1) (setq sel (vl-catch-all-apply 'ssget arg)) (setvar 'nomutt 0) (if (not (vl-catch-all-error-p sel)) sel) ) ;; Get MLeader Attributes - Lee Mac ;; Returns an association list of attribute tags & object IDs for all attributes held by an mleader block ;; mld - [vla] MLeader vla-object ;; Returns: [lst] List of ((<Attribute Tag> . <Object ID>) ... ) (defun LM:getmleaderattributes ( mld / rtn ) (vlax-for obj (vla-item (vla-get-blocks (vla-get-document mld)) (vla-get-contentblockname mld)) (if (and (= "AcDbAttributeDefinition" (vla-get-objectname obj)) (= :vlax-false (vla-get-constant obj)) ) (setq rtn (cons (cons (strcase (vla-get-tagstring obj)) (LM:intobjectid obj)) rtn)) ) ) (reverse rtn) ) ;; Object ID (integer) - Lee Mac ;; Returns an integer representing the ObjectID of a supplied VLA-Object ;; Compatible with 32-bit & 64-bit systems (defun LM:intobjectid ( obj ) (if (vlax-property-available-p obj 'objectid32) (defun LM:intobjectid ( obj ) (vla-get-objectid32 obj)) (defun LM:intobjectid ( obj ) (vla-get-objectid obj)) ) (LM:intobjectid obj) ) ;; Set MLeader Attribute Value - Lee Mac ;; obj - [vla] MLeader vla-object ;; idx - [int] Attribute Definition Object ID ;; str - [str] Attribute value (defun LM:setmleaderattributevalue ( obj idx str ) (if (vlax-method-applicable-p obj 'setblockattributevalue32) (defun LM:setmleaderattributevalue ( obj idx str ) (vla-setblockattributevalue32 obj idx str)) (defun LM:setmleaderattributevalue ( obj idx str ) (vla-setblockattributevalue obj idx str)) ) (LM:setmleaderattributevalue obj idx str) ) ;; List Box - Lee Mac ;; Displays a DCL list box allowing the user to make a selection from the supplied data. ;; msg - [str] Dialog label ;; lst - [lst] List of strings to display ;; bit - [int] 1=allow multiple; 2=return indexes ;; Returns: [lst] List of selected items/indexes, else nil (defun LM:listbox ( msg lst bit / dch des tmp rtn ) (cond ( (not (and (setq tmp (vl-filename-mktemp nil nil ".dcl")) (setq des (open tmp "w")) (write-line (strcat "listbox:dialog{label=\"" msg "\";spacer;:list_box{key=\"list\";multiple_select=" (if (= 1 (logand 1 bit)) "true" "false") ";width=50;height=15;}spacer;ok_cancel;}" ) des ) (not (close des)) (< 0 (setq dch (load_dialog tmp))) (new_dialog "listbox" dch) ) ) (prompt "\nError Loading List Box Dialog.") ) ( t (start_list "list") (foreach itm lst (add_list itm)) (end_list) (setq rtn (set_tile "list" "0")) (action_tile "list" "(setq rtn $value)") (setq rtn (if (= 1 (start_dialog)) (if (= 2 (logand 2 bit)) (read (strcat "(" rtn ")")) (mapcar '(lambda ( x ) (nth x lst)) (read (strcat "(" rtn ")"))) ) ) ) ) ) (if (< 0 dch) (unload_dialog dch) ) (if (and tmp (setq tmp (findfile tmp))) (vl-file-delete tmp) ) rtn ) ;; Get Cell - Lee Mac ;; If the supplied point lies within a cell boundary, ;; returns a list of: (<VLA Table Object> <Row> <Col>) (defun LM:getcell ( lst pnt / dir ) (setq dir (vlax-3D-point (trans (getvar 'viewdir) 1 0)) pnt (vlax-3D-point pnt) ) (vl-some '(lambda ( tab / row col ) (if (= :vlax-true (vla-hittest tab pnt dir 'row 'col)) (list tab row col) ) ) lst ) ) ;; ObjectID - Lee Mac ;; Returns a string containing the ObjectID of a supplied VLA-Object ;; Compatible with 32-bit & 64-bit systems (defun LM:objectid ( obj ) (eval (list 'defun 'LM:objectid '( obj ) (if (wcmatch (getenv "PROCESSOR_ARCHITECTURE") "*64*") (if (vlax-method-applicable-p (vla-get-utility (LM:acdoc)) 'getobjectidstring) (list 'vla-getobjectidstring (vla-get-utility (LM:acdoc)) 'obj ':vlax-false) '(LM:ename->objectid (vlax-vla-object->ename obj)) ) '(itoa (vla-get-objectid obj)) ) ) ) (LM:objectid obj) ) ;; Entity Name to ObjectID - Lee Mac ;; Returns the 32-bit or 64-bit ObjectID for a supplied entity name (defun LM:ename->objectid ( ent ) (LM:hex->decstr (setq ent (vl-string-right-trim ">" (vl-prin1-to-string ent)) ent (substr ent (+ (vl-string-position 58 ent) 3)) ) ) ) ;; Hex to Decimal String - Lee Mac ;; Returns the decimal representation of a supplied hexadecimal string (defun LM:hex->decstr ( hex / foo bar ) (defun foo ( lst rtn ) (if lst (foo (cdr lst) (bar (- (car lst) (if (< 57 (car lst)) 55 48)) rtn)) (apply 'strcat (mapcar 'itoa (reverse rtn))) ) ) (defun bar ( int lst ) (if lst (if (or (< 0 (setq int (+ (* 16 (car lst)) int))) (cdr lst)) (cons (rem int 10) (bar (/ int 10) (cdr lst))) ) (bar int '(0)) ) ) (foo (vl-string->list (strcase hex)) nil) ) ;; Start Undo - Lee Mac ;; Opens an Undo Group. (defun LM:startundo ( doc ) (LM:endundo doc) (vla-startundomark doc) ) ;; End Undo - Lee Mac ;; Closes an Undo Group. (defun LM:endundo ( doc ) (while (= 8 (logand 8 (getvar 'undoctl))) (vla-endundomark doc) ) ) ;; Active Document - Lee Mac ;; Returns the VLA Active Document Object (defun LM:acdoc nil (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object)))) (LM:acdoc) ) ;;----------------------------------------------------------------------;; (vl-load-com) (princ (strcat "\n:: LengthAreaField.lsp | Version 1.3 | \\U+00A9 Lee Mac " ((lambda ( y ) (if (= y (menucmd "m=$(edtime,0,yyyy)")) y (strcat y "-" (menucmd "m=$(edtime,0,yyyy)")))) "2017") " www.lee-mac.com ::" "\n:: \"LF\" for Length Field | \"AF\" for Area Field ::" ) ) (princ) ;;----------------------------------------------------------------------;; ;; End of File ;; ;;----------------------------------------------------------------------;; LengthAreaFieldV1-3 (LF LFM - AF AFM - CL) (DIMENSIONS too) MODIFY.lspFetching info... Quote
Lee Mac Posted February 23, 2020 Posted February 23, 2020 On 2/23/2020 at 11:58 AM, Davide said: I need to bypass the step "Specify point or table cell [Object eXit]" to have the possibility to select the object as default option? I need to put dimensions value in an attribute and I don't want every time to type the "O" for object. Expand Change: (defun LM:outputtext ( tag str / ent enx flg idx obj oid sel tab tmp typ ) to: (defun LM:outputtext ( tag str / ent enx flg idx obj oid sel tab tmp typ ) (setq flg t) Quote
Davide Posted February 23, 2020 Posted February 23, 2020 On 2/23/2020 at 12:48 PM, Lee Mac said: Change: (defun LM:outputtext ( tag str / ent enx flg idx obj oid sel tab tmp typ ) to: (defun LM:outputtext ( tag str / ent enx flg idx obj oid sel tab tmp typ ) (setq flg t) Expand Grazie. Dankeschön. Thank you. Quote
