Help modifying a lisp
enthralled
How can I make this work, given that I want to select the descriptive text object before executing this lisp, and the only prompt I want is to select the objects to be transferred into the new layer:
;;; LYRFRMTXT
;;; Written by David Forbus
;;; LYRFRMTXT prompts a user for a Text string
;;; LYRFRMTXT then prompts a user for an object and then
;;; modifies the layer of the entity to a layer named by the text string.
(defun c:LYRFRMTXT (/ o1 o1n o2 o2n txt elist cntr)
(setvar "cmdecho" 0)
(setq o1(entget(car(entsel "\nPick descriptive Text object: "))))
(setq o1n(assoc 1 o1))
(setq txt(cdr o1n))
(princ "\n Select entities for layer change.")
(if (setq o2n(ssget))
(setq cntr 0)
(while (< cntr (sslength o2n))
(setq o2(ssname o2n cntr))
(setq elist(entget o2))
(setq elist(subst (cons 8 txt)(assoc 8 elist) elist))
(entmod elist)
(setq cntr(+ cntr 1))
(princ "\n select error")
Sure, you can always take the user input out of the function.
LYRFRMTXT  only needs the txt variable, you can provide it as a parameter.
For example:
c:LM1 contains what I took away from LYRFRMTXT .
c:LM2 just permits you to hard code a layer
(defun c:LM2 ( / )
  (LYRFRMTXT "Layer1")
(defun c:LM1 ( / o1 o1n txt)
  (setq o1 (entget(car(entsel "\nPick descriptive Text object: "))))
  (setq o1n (assoc 1 o1))
  (setq txt (cdr o1n))
  (LYRFRMTXT txt)
(defun LYRFRMTXT ( txt / o2 o2n elist cntr)
  (princ "\nSelect entities for layer change: ")
  (if (setq o2n (ssget))
      (setq cntr 0)
        (entmod elist)
