kalindiberad Posted December 25, 2018 Share Posted December 25, 2018 How to set up a default drawing directory? Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 25, 2018 Share Posted December 25, 2018 Knowledge is power. Find some here. Merry Christmas. https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/AutoCAD-Core/files/GUID-0A1A3D99-15F9-4A6C-BCC0-D7F2695BAD8B-htm.html Quote Link to comment Share on other sites More sharing options...
kalindiberad Posted December 26, 2018 Author Share Posted December 26, 2018 Thank you.Will definitely follow this Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 27, 2018 Share Posted December 27, 2018 We have a server set up so we have a \Autodesk directory which has sub folders, printers, default dwgs, lisp etc these are found by settings using. This is easier than adding to the very deep default directories set up by Autodesk. Like wise in this directory is our custom menus. Config Files support Trusted paths Template location Printers etc As we have multiple users we have a lisp to do most of the work of setting up. Can re post if you need it. Quote Link to comment Share on other sites More sharing options...
