Convert numbers to words. Function from Lee Mac. Question...
Hello everyone. I found this code in the forum:
(defun LM:int->words ( n / f1 f2 )
    (defun f1 ( n )
        (if (< n 20)
            (nth (fix n) '("" "one" "two" "three" "four" "five" "six" "seven" "eight" "nine" "ten" "eleven" "twelve" "thirteen" "fourteen" "fifteen" "sixteen" "seventeen" "eighteen" "nineteen"))
            (strcat (nth (- (fix (/ n 10)) 2) '("twenty" "thirty" "forty" "fifty" "sixty" "seventy" "eighty" "ninety")) " " (f1 (rem n 10)))
    (defun f2 ( n l )
        (cond
            (   (null l) (f1 n))
            (   (< n (caar l)) (f2 n (cdr l)))
            (   (vl-string-right-trim " " (strcat (f2 (fix (/ n (caar l))) (cdr l)) " " (cadar l) " " (f2 (rem n (caar l)) (cdr l)))))
    (if (zerop n)
        "zero"
            (f2 n
                    (1e18 "quintillion")
                    (1e15 "quadrillion")
                    (1e12 "trillion")
                    (1e09 "billion")
                    (1e06 "million")
                    (1e03 "thousand")
                    (1e02 "hundred")
Tell me please who knows how to make words-> int.
For example:
From "twenty one thousand five hundred thirty seven" in 21537
I think the trick here is to convert the text number to lists. If you look at Lee Macs String to List (LM:STR->LST) function that might help.
Make up 7 lists, one for each power of 10 description ("quintillion" "quadrillion" "trillion" "billion" "million" "thousand" "hundred" "tens")
Use Lee Macs LM:STR-LST and have the deliminator as the power description. Also check if the number is that big and if not put a blank in that position.
Then move on to create the next power list, using item 2 of the list before
So in your example, in the list
'Thousand' if would be ("Twenty One" "five hundred thirty seven")
'Hundred would be ("Five" "thirty seven")
'Tens' would be ("thirty seven" "")
Then you can work it all out from the descriptions. You will need a loop in there in case for example you have three hundred two thousand five hundred and thirty seven.
Maybe that will get you started?
Thank you very much for the answers.
As posted at The Swamp, here are a pair of complementary functions:
Integer to Words
    (defun f1 ( n )
        (if (< n 20)
    (defun f2 ( n l )
        (cond
            (   (null l) (f1 n))
    (if (zerop n)
        "zero"
            (f2 n
                    (1e12 "trillion")
                    (1e09 "billion")
                    (1e06 "million")
                    (1e03 "thousand")
                    (1e02 "hundred")
Words to Integer
(defun LM:words->int ( s / f1 f2 )
    (defun f1 ( s l / p )
        (cond
            (   (null l)
                (cond
                    (   (vl-position (vl-string-trim " " s)
                    (   0   )
            (   (not (setq p (vl-string-search (car l) s))) (f1 s (cdr l)))
            (   (+ (* 10 (- 10 (length l))) (f1 (substr s (+ 2 p (strlen (car l)))) (cdr l))))
    (defun f2 ( s l / p )
        (cond
            (   (null l) (f1 s '("twenty" "thirty" "forty" "fifty" "sixty" "seventy" "eighty" "ninety")))
            (   (not (setq p (vl-string-search (caar l) s))) (f2 s (cdr l)))
            (   (+ (* (f2 (substr s 1 p) (cdr l)) (cadar l)) (f2 (substr s (+ 2 p (strlen (caar l)))) (cdr l))))
    (if (= "zero" (strcase s t))
        0
        (f2 (strcase s t)
                ("quintillion" 1e18)
                ("quadrillion" 1e15)
                ("trillion"    1e12)
                ("billion"     1e09)
                ("million"     1e06)
                ("thousand"    1e03)
                ("hundred"     1e02)
Examples:
_$ (rtos (LM:words->int (LM:int->words 3)) 2 0)
"3"
_$ (rtos (LM:words->int (LM:int->words 31)) 2 0)
"31"
_$ (rtos (LM:words->int (LM:int->words 314)) 2 0)
"314"
_$ (rtos (LM:words->int (LM:int->words 3141)) 2 0)
"3141"
_$ (rtos (LM:words->int (LM:int->words 31415)) 2 0)
"31415"
_$ (rtos (LM:words->int (LM:int->words 314159)) 2 0)
"314159"
_$ (rtos (LM:words->int (LM:int->words 3141592)) 2 0)
"3141592"
_$ (rtos (LM:words->int (LM:int->words 31415926)) 2 0)
"31415926"
_$ (rtos (LM:words->int (LM:int->words 314159265)) 2 0)
"314159265"
_$ (rtos (LM:words->int (LM:int->words 3141592653)) 2 0)
"3141592653"
_$ (rtos (LM:words->int (LM:int->words 31415926535)) 2 0)
"31415926535"
_$ (rtos (LM:words->int (LM:int->words 314159265358)) 2 0)
"314159265358"
_$ (LM:int->words 314159265358)
"three hundred fourteen billion one hundred fifty nine million two hundred sixty five thousand three hundred fifty eight"
_$ (rtos (LM:words->int "three hundred fourteen billion one hundred fifty nine million two hundred sixty five thousand three hundred fifty eight") 2 0)
"314159265358"
Edited by Lee Mac
Integer to Words
    (defun f1 ( n )
        (if (< n 20)
    (defun f2 ( n l )
        (cond
            (   (null l) (f1 n))
    (if (zerop n)
        "zero"
            (f2 n
                    (1e12 "trillion")
                    (1e09 "billion")
                    (1e06 "million")
                    (1e03 "thousand")
                    (1e02 "hundred")
Words to Integer
        (cond
            (   (null l)
                (cond
                    (   0   )
        (cond
        0
        (f2 (strcase s t)
                ("trillion"    1e12)
                ("billion"     1e09)
                ("million"     1e06)
                ("thousand"    1e03)
                ("hundred"     1e02)
Examples:
"3"
"31"
"314"
"3141"
"31415"
"314159"
"3141592"
"31415926"
"314159265"
"3141592653"
"31415926535"
"314159265358"
"314159265358"
Thank you very much, Lee.
