Move objects to new layer(s) based upon color??
ILoveMadoka
So It seems Autocad uses all uppercase letters for paper and model space. Where BricsCAD only use the first letter uppercase. so when looking a the list with vl-remove it seems to be case sensitive.
"*PAPER_SPACE"  /=  "*Paper_Space" so it wasn't removing them.
This should remove them now and not get stuck in a loop.
(defun C:LayerColor (/ SS ent lay e blkname blklst entlst lst)
  (vl-load-com)
  (if (setq SS (ssget "_X" '((8 . "0") (-4 . "<NOT") (0 . "INSERT") (-4 . "NOT>") (410 . "Model"))))
    (foreach obj (vl-remove-if 'listp (mapcar 'cadr (ssnamex SS)))
      (setq ent (vlax-ename->vla-object obj))
      (if (and (setq lay (itoa (vla-get-Color ent))) (= lay "256"))
        (setq lay (itoa (cdr (assoc 62 (tblsearch "layer" (vla-get-Layer ent))))))
      (if (not (tblsearch "layer" lay))
        (entmake (list (cons 0 "LAYER")
                       (cons 100 "AcDbSymbolTableRecord")
                       (cons 100 "AcDbLayerTableRecord")
                       (cons 2 lay)
                       (cons 62 (atoi lay))
                       (cons 70 0)
      (vla-put-layer ent lay)
  (if (setq blklst (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))))
      (vlax-for blk blklst (and (eq "AcDbBlockReference" (vla-get-ObjectName blk)))
        (setq lst (cons (vla-get-Name blk) lst))
      (setq lst (vl-remove "*PAPER_SPACE" lst))
      (setq lst (vl-remove "*MODEL_SPACE" lst))
      (foreach blkname lst
        (setq ent (tblobjname "BLOCK" blkname))
        (while (setq ent (entnext ent))
          (setq entlst (cons ent entlst))
        (foreach ent entlst
          (setq ent (vlax-ename->vla-object ent))
                           (cons 2 lay)
                           (cons 70 0)
Edited by mhupp
  • Thanks 1
in my lisp collection i have this, but not remember the original source for give credit
(defun c:color2layer (/ atts doc lay lays lokt)
(defun laycheck (ent color / lay)
(if (< 0 color 256)
(setq lay (vla-add lays (strcat "Color-" (itoa color))))
(vla-put-layer ent (vla-get-name lay))
(vla-put-color lay color)
(vla-put-color ent acbylayer)
(setq doc (vla-get-activedocument (vlax-get-acad-object))
lays (vla-get-layers doc)
(vlax-for lay lays
;;check for locked layers
(if (eq :vlax-true (vla-get-lock lay))
(setq lokt (cons (vla-get-name lay) lokt))
(vla-put-lock lay :vlax-false)
(vla-startundomark doc)
(vlax-for blk (vla-get-blocks doc)
(if (and (eq (vla-get-isxref blk) :vlax-false)
(not (vl-string-search "|" (vla-get-name blk)))
(vlax-for ent blk
(laycheck ent (vla-get-color ent))
(if (and (vlax-property-available-p ent "hasattributes")
(vla-get-hasattributes ent)
(setq atts (vlax-invoke ent "getattributes"))
(foreach att atts
(laycheck att (vla-get-color att))
(vla-update att)
(if lokt
;;reset locked layers
(foreach lay lokt
(vla-put-lock (vla-item lays lay) :vlax-true)
(vla-endundomark doc)
(princ "\nDone!")
  • Thanks 1
