Alex_Miller Posted December 3, 2018 Posted December 3, 2018 I am trying to draw a cylinder using the method vla-AddCylinder. (vl-load-com) (setq center (vlax-3d-point 0 0 0) cylRadius 5 cylHeight 50) (setq modelSpace (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-acad-object)))) (vla-AddCylinder modelSpace center cylRadius cylHeight) The cylinder is extruding along axis Z. I would make the cylinder be directed along another axis, for example X. Quote
Lee Mac Posted December 3, 2018 Posted December 3, 2018 Construct the cylinder relative to the WCS plane and then transform as required - here is an example. 1 Quote
Alex_Miller Posted December 3, 2018 Author Posted December 3, 2018 Lee Mac Okay. Thank you. I'll look with interesting. Quote
BIGAL Posted December 4, 2018 Posted December 4, 2018 Just another use rotate3d after making object or set a ucs then draw object in that plane. 1 Quote
Alex_Miller Posted December 4, 2018 Author Posted December 4, 2018 BIGAL Yes. I guess that sometimes using the function entmake must be easier. Quote
