Spartacus Posted November 30, 2018 Posted November 30, 2018 Currently using AMEP 2019. When I bring in a 2x4 light from the Tool Palette, the osnap command "Endpoint" does not show up when I hover over one corner or any corner. the osnap command "Insert" & "electrical connector" will work correctly. I never had this problem with older versions. Is there is setting that needs to be changed? Thanks for your input in advance! Quote
