dear,
i need to create new linetype for circle on lwpolyline vertexes only not in between vertexes
and small gap from circle as i attached file
thanking you
A few different methods come to mind, trim the lines with a offset, use a wipeout then lines still go to centre of circle.
I am sure this has been discussed before in particular lines going to a end point to reflect true length.
