Hi,
I need use (command ".save" pth) in my reactor for automatic back up after 30 minutes. But I can not figure out how to write this in Visual LISP. I want save current unsaved dwg to new file, but current dwg has to remain unchanged and still be active.
Method (vla-saveAs doc) makes new file but makes active just this new file and close the old one. (vla-save doc) saves only without creating new file.
Following code is a part of commandEnded callback reactor:
(defun GM:createBackUp  (cmd / doc pth)
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (setq pth (strcat (getvar "TEMPPREFIX")
                    (vl-string-right-trim ".dwg" (getvar "DWGNAME"))
                    "_"
                    (rtos (getvar "CDATE") 2 6)
                    ".dwg"))
  (if (not (wcmatch cmd "QSAVE,SAVEAS"))
      ;(command ".save" pth) ;;;!!!!
      (princ "\nCurrent drawing has been saved."))
  (vl-file-copy (strcat (getvar "DWGPREFIX") (getvar "DWGNAME")) pth))
  (princ (strcat "\nBackup \"" (getvar "DWGNAME") "\" has been created. (" pth ")")))
  Thanks.
Hi,
Perhaps try with vl-file-copy function (I remember ronjonp using it here within reactor for a similar task)
Thanks for replies, but neither one function doesn't backup actual unsaved drawing. They make a copy of drawing from last saving only. It seems it isn't possible, what i would like.
Expand
The program in the first link I provided does exactly this.
Expand
You could try alternative approach with the SendCommand method (example).
Expand
I tried it several times, but new entities (created after manual save) are still missing in backup file. Probably I do something wrong, but i don't know what.
Expand
I have not known this method. I am trying this way now but I have problem with dialog box, it always opens.
(defun c:test  (/)
  (vla-sendCommand doc "_.save C:\\Users\\Marek\\Desktop\\testBackUp.dwg ")
This does what i want
(command "._save" "C:\\Users\\Marek\\Desktop\\testBackUp.dwg")
(defun c:test  (/)
Expand
Try setting the filedia variable to 0, and reset it back to its original value, example:
(setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
(setq dsktop (strcat (getenv "userprofile") "\\Desktop\\"))
(setq fd (getvar 'filedia))
(setvar 'filedia 0)
(vla-SendCommand doc (strcat "_.save " dsktop "testBackUp.dwg" "\r"))
(setvar 'filedia fd)
Sorry for my late reply!
(setvar 'filedia 0)
Expand
vla-SendCommand has strange behaviour or it is feature? it executes command after function is finshed, so variable FILEDIA is already back on 1. If I change FILEDIA on 0 manually, it works fine.
From help (I read this, but I didn't understand):
This method is generally synchronous. However, if the command sent with this method requires any user interaction (such as picking a point on the screen) then this method will continue as soon as the user input begins. The command will then continue to be processed asynchronously.
Edited by Mara821
I am idiot
Expand
Good call, I never tested it much actually -
Indeed it is synchronous:
(vla-SendCommand (vla-get-ActiveDocument (vlax-get-acad-object))
  (strcat
    (vl-prin1-to-string '(command "_.CIRCLE"  pause pause)) "\r"
    (vl-prin1-to-string '(command "_.LINE" pause pause)) "\r"
Because the above will instantly prompt for errors when calling the command, or even if its 2 separate calls like this:
  (strcat
  (strcat
Would mean that it does its job, sends the string to be executed in the accoreconsole console (the one thats not in VLIDE)..
And returns nil instantly, without waiting the user for inputs from the sended string that was executed.
Maybe thats because the return from the SendCommand method doesn't depent on the execution string's result (it just sends it and instantly returns nil, without having to wait)
Meaning that the LISP code continues evaluating, while the sended string for execution waits for inputs or is just sended with some delay (what a mess).
Now that we observed how it behaves, then why not pass a setvar/getvar expression in it :
(defun C:test ( / doc dsktop fd )
    (strcat
      "(setvar 'filedia 0)" "\r"
      "(setvar 'filedia " (itoa fd) ")" "\r"
  ); vla-SendCommand
NOTEs:
"\r" simulates hitting ENTER key
(vl-prin1-to-string '(command ...)) makes easier to write the call
Edited by Grrr
  • Thanks 1
I don't understand the advantage of using vla-sendcommand.
In what way does it improve this?:
Expand
I guess so that it could be used within a reactor callback function.
Aside, I wasn't aware that the SAVE command could produce a SAVEAS without changing the active drawing - that's a new one for me, thanks.
