pixel8er Posted November 29, 2018 Author Posted November 29, 2018 (edited) I think I might stick with the standard ACI colours.. (setq c 150) seems like the True Colours and Pantone Colours might be too hard to implement Edited November 29, 2018 by pixel8er Edit code Quote
ronjonp Posted November 29, 2018 Posted November 29, 2018 On 11/17/2018 at 4:55 AM, pixel8er said: Close. I noticed the linework changed colour, but it's the hatch I want to be coloured depending on the closed polyline m² area. Different m² areas will be different hatch colours. I'd also like to put each m² hatch on a seperate layer. Expand Maybe this will give you some ideas: ;; Written by PBEJSE on CADTutor ;; Post #4 https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/multiple-polyline-area-labels/td-p/3459894 ;; Relies on TEXTSIZE variable for text size ;; 280316 - Tharwat updated field properties in post #2 in above link ;; 040416 - Tharwat updated to add hatch based on area ranges (command "-dimstyle" "R" "Standard") (defun c:mfah (/ acsp ar bitversion clr e h id ins ln o p ptlist scale ss strfield sum txt verts) (setq ins (getvar "insunits")) (cond ((= (setq ins (getvar "insunits")) 4) ;if insunits=4 then apply 1 x cannoscale (setvar "dimscale" (/ 1.0 (getvar "CANNOSCALEVALUE"))) ) ((= ins 6) ;if insunits=6 then apply 0.001 x cannoscale (setvar "dimscale" (/ 0.001 (getvar "CANNOSCALEVALUE"))) ) ) (setq scale (getvar "DIMSCALE")) (setq ln (strcat "U-TEXT-AREA-" (rtos scale 2 0))) (command "-LAYER" "m" ln "co" "7" ln "p" "p" ln "") (setvar "TEXTSTYLE" "Standard") (setvar "TEXTSIZE" (* 1.8 (getvar "DIMSCALE"))) (setq bitversion (> (strlen (vl-prin1-to-string (vlax-get-acad-object))) 40) acsp (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object)))) ) (if (setq ss (ssget "_X" '((0 . "LWPOLYLINE") (-4 . "&") (70 . 1) (410 . "Model")))) (repeat (sslength ss) (setq e (ssname ss 0) sum '(0 0) verts (cdr (assoc 90 (entget e))) ) (setq ptlist (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget e)))) (foreach x ptlist (setq sum (mapcar '+ x sum))) (setq o (vlax-ename->vla-object e)) (setq id (if bitversion (vlax-invoke-method (vla-get-utility (vla-get-activedocument (vlax-get-acad-object))) 'getobjectidstring o :vlax-false ) (itoa (vla-get-objectid o)) ) strfield (strcat "%<\\AcObjProp Object(%<\\_ObjId " id ">%).Area \\f \"%lu2%pr0%ps[, m²]%ds44\">%" ) txt (vla-addmtext acsp (setq p (vlax-3d-point (mapcar '/ sum (list verts verts)))) 0 strfield ) ) (vla-put-attachmentpoint txt acattachmentpointmiddlecenter) (vla-put-insertionpoint txt p) ;; Make the hatch (command "_.-HATCH" "_P" "SOLID" "_S" e "" "") ;; Set the hatch to variable 'h' (setq h (entlast)) ;; Get the area of the polyline (setq ar (vla-get-area o)) ;; Define a color based off of area. To get the number for your colors use: (acad_truecolordlg 1) ;; Pick your color and see what it returns. (setq clr (cond ;; Area is <= 50 set color to gray ((<= ar 50) '((62 . 8) (420 . 8421504))) ;; Area is <= 100 set color to red ((<= ar 100) '((62 . 1) (420 . 16711680))) ;; Area is <= 150 set color to green ((<= ar 150) '((62 . 3) (420 . 65280))) ;; Area is between 185 and 190 or between 301 and 351 set it to your color ((or (< 185 ar 190) (< 301 ar 351)) '((62 . 244) (420 . 11737633))) ) ) ;; If we have a color set make the hatch that color (and clr (entmod (append (entget h) clr))) ;; Remove the entity from the selset (ssdel e ss) ) (princ "\n0 Objects found:") ) (princ) ) (vl-load-com) Quote
