BIGAL Posted June 11, 2024 Posted June 11, 2024 Did you only do the menu customisation inside CUI and save as acad.cuix ? You can copy the correct CUIX but a pain as its the default name. Thats why I save into custom MNU and custom cuix for ribbons. Yes Bricscad V20 works. May be time to upgrade 2007 is pretty old. Bricscad is now V24. Quote
SLW210 Posted June 11, 2024 Posted June 11, 2024 On 6/10/2024 at 10:38 PM, filapost said: Yes , but i am afraid i will lose my menu and ribbon customization. Expand I believe you can export and then import your profile among other settings. How to export, import, backup, and transfer settings to and from AutoCAD (autodesk.com) 1 Quote
filapost Posted June 18, 2024 Posted June 18, 2024 THE PROBLEM WAS CAUSED FROM A CORRUPTED PROFILE. I DID EXACTLY WHAT YOU SAID AND IT WORKS PERFECTLY, THANKS A LOT. 1 Quote
