BIGAL Posted June 11 Share Posted June 11 Did you only do the menu customisation inside CUI and save as acad.cuix ? You can copy the correct CUIX but a pain as its the default name. Thats why I save into custom MNU and custom cuix for ribbons. Yes Bricscad V20 works. May be time to upgrade 2007 is pretty old. Bricscad is now V24. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 11 Share Posted June 11 11 hours ago, filapost said: Yes , but i am afraid i will lose my menu and ribbon customization. I believe you can export and then import your profile among other settings. How to export, import, backup, and transfer settings to and from AutoCAD (autodesk.com) 1 Quote Link to comment Share on other sites More sharing options...
filapost Posted June 18 Share Posted June 18 THE PROBLEM WAS CAUSED FROM A CORRUPTED PROFILE. I DID EXACTLY WHAT YOU SAID AND IT WORKS PERFECTLY, THANKS A LOT. 1 Quote Link to comment Share on other sites More sharing options...
