Jef! Posted November 2, 2018 Share Posted November 2, 2018 Exclusive NOR the output should be 1 if both inputs are the same, 0/0 (operator bit 8 ) + 1/1 (operator bit 1). So operator bit 9. (boole 9 0 0) and (boole 9 1 1) should return 1, while (boole 9 0 1) and (boole 9 1 0) should return 0 I just tested in Cad 2013/2014/2015 and 2016 and... (boole 9 0 0) and (boole 9 1 1) return -1 while (boole 9 0 1) and (boole 9 1 0) return -2. (!) I worked around that bug using "not XOR", ie: (- 1 (boole 6 0 0)), but I would still be curious if other and/or newer versions of Autocad than the above-mentioned (2012- / 2017+) had/still have that (boole 9 bug. I would also be curious to know if BricsCad have the same bug. What cad software do you use, what version and what does (boole 9 return? Thanks and have a great week end! Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted November 2, 2018 Share Posted November 2, 2018 This is not a bug. Signed integers are stored in 32-bit 2's complement representation and so we have the following when performing the bitwise operations: (boole 9 0 1) = 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 = 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 = 1 ----------------------------------------------------------------------- NOT XOR 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 = -2 1 1 Quote Link to comment Share on other sites More sharing options...
Jef! Posted November 3, 2018 Author Share Posted November 3, 2018 36 minutes ago, Lee Mac said: This is not a bug. Signed integers are stored in 32-bit 2's complement representation and so we have the following when performing the bitwise operations: (boole 9 0 1) = 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 = 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 = 1 ----------------------------------------------------------------------- NOT XOR 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 = -2 Oh! Right. Each bit of int1 is paired with the corresponding bit of int2. I was checking with 2 input logic gate literature. My bad. As long as I'm comparing only 1's and 0's, (- 1 (boole 6 0 0)) does what I need but a more robust solution to get 1 if and only if both int inputs bit x are the same would be as follow (boole 1 x (boole 9 int1 int2)) (boole 1 1 (boole 9 0 0)) & (boole 1 1 (boole 9 1 1)) return 1 (boole 1 1 (boole 9 0 1)) & (boole 1 1 (boole 9 1 0)) return 0 Does it make sense? (or maybe I should ask is there anything that would make more sense?) Quote Link to comment Share on other sites More sharing options...
