gbradley Posted November 1, 2018 Posted November 1, 2018 How can I create a workplane 22.5° off from YZ Plane? AutoDesk Inventor 2019 Quote
gbradley Posted November 6, 2018 Author Posted November 6, 2018 I ended up creating a Sketch with a Flat Face, and then created a plane parallel with the Face Tangent with the outside Diameter. Then I cut away my extrusion. Quote
nigh Posted December 18, 2018 Posted December 18, 2018 Create plane ► select Z axis ► select YZ plane input angle. 1 Quote
