Hi Everyone! Help me!
I just modify Rev-Cloud Lisp using "RECTANG" Command.
I want to change last step! we need after finish Rev-Cloud to set Rotation "0" in "RECTANG" Command.
(defun C:Revc ()
 (defun *error* (msg)
    (if acDoc
      (vla-endundomark acDoc)
    (cond ((not msg))                                                   ; Normal exit
          ((member msg '("Function cancelled" "quit / exit abort")))    ; <esc> or (quit)
          ((princ (strcat "\n** Error: " msg " ** ")))
    )        ; Fatal error, display it
(defun RtoD (nbrOfRadians)
  (/ (* nbrOfRadians 180.0) pi)
(defun DtoR (nbrOfDegrees)
  (* (/ nbrOfDegrees 180.0) pi)
   (if (not (tblsearch "LAYER" "REV"))
        (entmakex '((0 . "LAYER")
                    (100 . "AcDbSymbolTableRecord")
                    (100 . "AcDbLayerTableRecord")
                    (2 . "REV")
                    (70 . 0)
                    (62 . 10)
                    (6 . "Continuous")
      (setvar 'clayer "REV")
  (setq oldosmode (getvar 'osmode))
  (setq ang (getvar 'snapang))
  (setvar 'osmode 0)
  (setq ang1 (cvunit ang "radians" "degrees"))
  (command "_.rectang" pause "R" ang1 pause)
  (while (> (getvar 'CmdActive) 0) (command pause))
  (setq rec (entlast))
  (setq arc (getvar 'DIMSCALE))
 (initget "Yes No")
  (setq
    cloud (getkword "Reverse Cloud direction [Yes/No] <No>: ")
    cloud (cond (cloud) (T "No")); No for Enter
     (command "_.REVCLOUD" "_Style" "_Normal" "_Arc" (* arc 2.5) "" "_Object" rec cloud)
     (command "_.rectang" "_none" "0,0" "R" 0 "_none" "0,0")
     (setq del (entlast))
     (command "_.erase" del "")
     (setvar "clayer" "0")
     (setvar 'osmode oldosmode)
(vl-load-com)
Hi there!
Between the (vl-load-com) and the (princ) lines (at the end), add these 2 lines
(command "_.rectang" "0,0" "R" "0" "1,1")
(entdel (entlast))
it will leave the rotation of rectangle at 0 after execution.
If this solves your problem, please mark this reply accordingly. Thanks and cheers.
  • Thanks 1
Hi Jef!
Thanks for your's help!.Now it's working fine.:beer:
Edited by Pugazh
