Creating Autocad Add-in installer
hi
I've some lisps, vlx, dll that works together,
i want to create an installer (exe or msi) that does the following :
1. paste the files to the specified location
 2.add path to autocad search location
 3. load partial cuix
 can you explain or refer to online resources?
Thanks
Shay
You could write it all in lisp, just get the end user to save the installer.lsp and then use drag and drop to run it a bit easier than using appload etc.
Do you have a add path and load menus examples.
Edited by BIGAL
hi BIGAL
i dont want the user to deal with autocad at all
i want external exe that does it all.
the same as the Autodesk marketplace installer
I guess the next post is I need a programmer, PREPARED TO PAY.
There has been some posts about doing installers but they may be 2-3 years old you will have to search.
What do you know about VBA, .net c# that’s what is needed.
I know someone who may be able to help but he would do it as a company thing meaning a cost involved.
When you become an authorised Autocad developer they will probably provide the tools to create an installer.
Edited by BIGAL
