fuccaro Posted October 25, 2018 Posted October 25, 2018 I wrote a quick Lisp to map an image onto a ... "sphere". Sometime in the (near?) future I will try to improve it, for the moment the image resolution is poor. I used a 3d mesh and AutoCAD limits its dimensions do 256x256. If someone wants to play with the lisp I wrote, draw a 2d shape starting from point 100,0,0 to right. Use a solid hatch on the closed shapes, enter the PLAN command, and maybe do a zoom to "extents". Start the lisp by typing "Miki" and... wait. On my computer it took almost 2 minutes to create the model. Have fun! CADTutor.LsP 2 Quote
Grrr Posted October 25, 2018 Posted October 25, 2018 Impressive work, if it runs slow then you could include time-tracking, also you might want to localise the variables (defun c:miki ( / time a a1 am an ang ax d drz fs im in m n o1 o2 od ox oz p p1 p2 p3 p4 pct r1 r2 rx rz ss) (setq time (getvar 'MILLISECS)) ; code.... (princ (strcat "\n < Elapsed time: " (rtos (/ (- (getvar 'MILLISECS) time) 1000.0) 2 6) " seconds. > " ) ) (princ) ) Quote
BIGAL Posted October 26, 2018 Posted October 26, 2018 (edited) I will try to find there is a post here about embossing lettering onto a curved surface, it’s relatively simple just extrude your lettering as a radial from the object centre then using union and subtract, trim the height of the lettering. Had problems I am using an iPad so search for cmagee94 and 3d shape for post. Will do seperate post how I get the link when using an IPad. Edited October 26, 2018 by BIGAL Quote
Steven P Posted November 9, 2018 Posted November 9, 2018 combining this with a LISP thing I found once to make the computer talk "Ho Ho Ho".. my colleagues are going to be so happy with me next week 1 Quote
