CAD Panacea Posted October 19, 2018 Posted October 19, 2018 If you do any presentation with or screen captures from your CAD application, you may have the need to quickly change background colors for various reasons. This post from about 9 years ago, includes some lisp code to do this in AutoCAD. Today’s post includes the lisp code to do the same thing in BricsCAD. Note that this version does not change the crosshair color(s), but in our testing BricsCAD will automatically set the opposite color for the crosshairs (white on black and black on white). The function is named TBC. After you load this lisp file, you can type in TBC and this will toggle the background color from Black to White and so on. See animated GIF at the bottom of this post. (vl-load-com) (defun c:TBC (/ pref col cur tm) (setq tm (getvar "tilemode")) (setq pref (vla-get-display (vla-get-Preferences (vlax-get-acad-object) ) ) ) (if (zerop tm) (setq cur (vla-get-graphicswinlayoutbackgrndcolor pref)) (setq cur (vla-get-graphicswinmodelbackgrndcolor pref)) ) (setq col (vlax-variant-value (vlax-variant-change-type cur vlax-vblong ) ) ) (if (not (or (eq col 0) (eq col 16777215))) (setq col 0) ) (cond ((zerop tm) (vla-put-graphicswinlayoutbackgrndcolor pref (vlax-make-variant (abs (- col 16777215)) vlax-vblong) ) ) (t (vla-put-graphicswinmodelbackgrndcolor pref (vlax-make-variant (abs (- col 16777215)) vlax-vblong) ) ) ) (vlax-release-object pref) (princ) ) View the full article Quote
