Using AutoCAD 2016, when I pick a point inside an area to HATCH, the frames of images attached to the drawing create boundaries for the hatch, even when the images are not visible and the image frame variable  is turned off. How can I avoid this? Thanks.
If the images are on a layer turned off should work then use draw order.
Expand
You are right!!! Even with the image off, and the image frame off, the hatch command detects the frame of the image if it is in a layer that is on. So I just changed the image to other layer and turned it off, and IT WORKED!! Problem solved. Thanks.
