Lisp: coordinates of points to excel sheet (+point number)
Yes i want this lisp because i give the co-ordinate the surveyors for stake out...so give me your lisp file and tell me how i use it and take coordinate from autocad to excel
Just GREAT
use this succesfuly.
Thanks
  • 1 month later...
Dear Sir,
I like the lisp used for exporting coordinate X,Y,Z. Do possible to change the Elevation Z to Length of the Drawing, and remain output of Coordinate X and Y?
  • 4 months later...
  VVA said:
stevesfr
what version MS OFFICE do you use ? (I did not test with Office 2007)
In any case I have a little changed programs. Now it is possible to keep in a text file csv or txt a format.
If option Excell does not work, try option Text file (csv a format) and to answer "YES" inquiry "Open text file? [Yes/No] :"
Commands:
COOR - export of coordinates
COORN-export of coordinates with numbering. Numbers of points are drawn by the text on the current layer, the current style, current height (TEXTSIZE)
COORT-export of coordinates with numbering where number considers the text nearest to a point
CoorNP-Coordinates + Numbers + Points. Draw points with current value of PDMODE and PDSIZE
COORNB - CoorNB-Coordinates + Block (Numbers + Points)
Rev9 - 2014-05-05 Settings (export XYZ YXZ; round)
HI, My friend i need ur help when i use CoorNP command and try to save it in text file there is comma "," missing in between Numbers E N Z
  • 4 months later...
it worked just fine until suddenly giving me this when i run and select a polyline
  Quote
Select objects: ; error: no function definition: nil
any thoughts on how to make it work
  • 4 months later...
Hi, I have used this LISP Routine with great success, however im running into a problem when working in a UCS. The coordinates output in the current UCS which is what i want, but the text is drawn in the world system. Which means i have to move the text and rotate it back to the ccorrect position. Is this something i am doing wrong or is there a Workaround for this?
(defun c:Test0008 (/ p1 oFile sFile tmp Separator i
;|Functions|; GetFormatFile aux:SelectFile grdx
;;_________________________________________________
(defun GetFormatFile (/ lsts)
(or *Format* (setq *Format* "csv"))
(setq lsts '(("csv" ";" "[<Csv>/Txt/Xls]")
("txt" " " "[Csv/<Txt>/Xls]")
("xls" "\t" "[Csv/Txt/<Xls>]")))
(setq mens (last (assoc *Format* lsts)))
(initget "Csv Txt Xls _csv txt xls")
(if (setq tmp (getkword (strcat "\nFormat file;" mens ": ")))
(setq *Format* tmp)
(setq Separator (cadr (assoc *Format* lsts)))
(defun aux:SelectFile ( Extension / ff)
(if (setq ff (getfiled "Select File" (if *TmpRutaFile* *TmpRutaFile* "") Extension 1))
(setq *TmpRutaFile* (strcat (vl-filename-directory ff) "\\"))
);c.if
ff
);c.defun
; grdx - graphic cross utility
(defun grdx (p col size / h)
(setq h (/ (getvar "viewsize") size))
(grdraw (list (- (car p) h) (- (cadr p) h))
(list (+ (car p) h) (+ (cadr p) h)) col 0)
(grdraw (list (- (car p) h) (+ (cadr p) h))
(list (+ (car p) h) (- (cadr p) h)) col 0)
p
);c.defun
;;--------------------- MAIN -----------------
(or *Prec* (setq *Prec* 4))
(setq p1 (getpoint "\nPick first point: "))
(while p1
(grdX p1 213 125)
(setq lstFile (cons p1 lstFile))
(setq p1 (getpoint " >> Pick Next point: "))
(cond
(lstFile
(initget (+ 4))
(if (setq tmp (getint (strcat "\nPrecisión;<" (itoa *Prec*) ">: ")))
(setq *Prec* tmp)
(GetFormatFile)
(setq sFile (aux:SelectFile *Format*))
(cond
(sFile
(setq i 1)
(setq oFile (open sFile "w"))
(write-line "COORDINATES OF POINTS" oFile)
(write-line (strcat "#" Separator "X" Separator "Y" Separator "Z") oFile)
(mapcar
(function
(lambda (pt)
(write-line (strcat (itoa i) Separator
(rtos (car pt) 2 *Prec*) Separator
(rtos (cadr pt) 2 *Prec*) Separator
(rtos (last pt) 2 *Prec*)
oFile)
(setq i (1+ i))
lstFile
);c.mapcar
(close oFile)
(alert (strcat "File: \n\n[" sFile "]\n\nhas been created."))
;;(startAPP (strcat "notepad.exe " sFile))
(command "shell" (strcat "start " sFile))
);c.cond
1b1K3T012C2a
  • 3 years later...
MODEL WORK.dwgFetching info... R5 tabord3.lspFetching info...
Hi Guys
I come to ask for an adaptation in a table, I will post the images and attachment to better understand,
I'm grateful for help.
As this is important to me, I will make a donation of 20 U$ for those who can, as thanks for the help.
bye
Edited by leo321
edit text
