janwillem89 Posted January 21, 2009 Posted January 21, 2009 Hello, As a rocky acad 2009 (civil) user the Lisp command is new to me and a big challenge. My job asks me to find the coordinates of points. The image has like 200 points, and I know more images like this are coming. Sofar I managed to match the picture with the drawing (correlate - match) and rotate the drawing (dview twist) so I can read the numbers of the points without getting a headache. Now I have to look up the coordinates of each point. Of course I can go with the cursor the the point, write down the XY coordinates on a paper, scan it in and send it to the office. Pretty much of a job! There must be a easier way. Is Lisp a solution? That would be: right click on the point, have the possibillity to fill in the point number; and the XYcoordinates, with the point number, are written to an excel sheet. I googled a bit but as far I could find people use the other way around only: excel coordinates to a drawing. Who knows a Lisp what can do this, or can someone help me out how to write a lisp like this? Thanks, Jan Quote
Tiger Posted January 21, 2009 Posted January 21, 2009 the points are in a DWG right? I'd use Data Extraction for this (under Tools). Explore it a bit, I think it's pretty self-explanatory but if any troubles, please come back. The problem I see is how to match the coordinates with the points. Do the Points have some kind of identification number attached to them, or are they just points? I have a lisp which prints out coordinates as MText of points that I have, I have to select all the points though. hmm....might have one that prints all coordinates of all points in one go, if your're interested? Quote
lpseifert Posted January 21, 2009 Posted January 21, 2009 From the Civil 3D menu... Points > Import/Export Points > Export Points If the points are plain autocad points and not Civil 3D points you'll need to convert them first. Points > Utilities > Convert from Autocad Points Quote
VVA Posted January 21, 2009 Posted January 21, 2009 >janwillem89 Try it If something will be not clear, I shall try to comment later. In the text in the basic comment in Russian. It is possible to take advantage Online translator: http://www.online-translator.com/Default.aspx?prmtlang=en Export of coordinates of the specified points, the chosen objects: points, blocks, polylines, splines in a text file or Excel. Text file — txt, or csv. A rounding off of coordinates according to current adjustments of a command _UNITS (LUPREC system variable) 3 commands Are certain COOR - export of coordinates COORN-export of coordinates with numbering. Numbers of points are drawn by the text on the current layer, the current style, current height (TEXTSIZE) COORT-export of coordinates with numbering where number considers the text nearest to a point New version see post #12 coorN.zipFetching info... Quote
Phiphi Posted February 5, 2009 Posted February 5, 2009 Could anyone please add a command to draw each POINT as well when using COORN. Thanks you Quote
Phiphi Posted February 7, 2009 Posted February 7, 2009 ...And making numbers can be like 5, 10, 15... Thanks Quote
Phiphi Posted February 8, 2009 Posted February 8, 2009 VVA said: >...3 commands Are certain COOR - export of coordinates COORN-export of coordinates with numbering. Numbers of points are drawn by the text on the current layer, the current style, current height (TEXTSIZE) COORT-export of coordinates with numbering where number considers the text nearest to a point Thank to command COORN, I can make a file of coordinates. After changing Z value, I am finding a LISP to draw lines/Pline back in CAD with points & ID marks beside. Any help is greatly appreciated. Quote
VVA Posted February 10, 2009 Posted February 10, 2009 Phiphi said: Could anyone please add a command to draw each POINT as well when using COORN. Thanks you Phiphi said: ...And making numbers can be like 5, 10, 15...Thanks Try it. Add new command CoorNP-Coordinates + Numbers + Points. Draw points with current value of PDMODE and PDSIZE. Add to command CoorN and CoorNP Increment of number New version see post #12 coorN.zipFetching info... Quote
Phiphi Posted February 10, 2009 Posted February 10, 2009 VVA said: Try it. Add new command CoorNP-Coordinates + Numbers + Points. Draw points with current value of PDMODE and PDSIZE.Add to command CoorN and CoorNP Increment of number Thank a lot, VVA. Can you please reset Numbers at middle & perpendicular to Points/Pline. Text height can be changed as well. Cheers, PP. CoorNP.zipFetching info... Quote
Oliver PT Posted August 1, 2009 Posted August 1, 2009 VVA your awesome! that works a bloody treat! Quote
stevesfr Posted August 1, 2009 Posted August 1, 2009 VVA said: Try it. Add new command CoorNP-Coordinates + Numbers + Points. Draw points with current value of PDMODE and PDSIZE.Add to command CoorN and CoorNP Increment of number The command coorNP is great except I can not get the program to write to Excel ! I get the following error. Save coordinates to [Text file/Excel/Not save] : E ; error: ActiveX Server returned the error: unknown name: UseSystemSeparators Command: Did I miss a setting? Save to user select file location does not appear line in save as Text. can you help me? How to save to Excel? Quote
VVA Posted August 2, 2009 Posted August 2, 2009 (edited) stevesfr what version MS OFFICE do you use ? (I did not test with Office 2007) In any case I have a little changed programs. Now it is possible to keep in a text file csv or txt a format. Quote How to save to Excel?If option Excell does not work, try option Text file (csv a format) and to answer "YES" inquiry "Open text file? [Yes/No] :" Commands: COOR - export of coordinates COORN-export of coordinates with numbering. Numbers of points are drawn by the text on the current layer, the current style, current height (TEXTSIZE) COORT-export of coordinates with numbering where number considers the text nearest to a point CoorNP-Coordinates + Numbers + Points. Draw points with current value of PDMODE and PDSIZE COORNB - CoorNB-Coordinates + Block (Numbers + Points) ... Rev9 - 2014-05-05 Settings (export XYZ YXZ; round) ECoor.LSPFetching info... ECoorE rev10b.zipFetching info... Edited October 16, 2015 by VVA fix small bug ECoorE rev10b 1 Quote
stevesfr Posted August 2, 2009 Posted August 2, 2009 VVA said: stevesfryou use what version MS OFFICE? (I did not test with Office 2007) In any case I have a little changed programs. Now it is possible to keep in a text file csv or txt a format. If option Excell does not work, try option Text file (csv a format) and to answer "YES" inquiry "Open text file? [Yes/No] :" PS especially it was not tested, mistakes are possible Mistakes are possible? I think so. New version will not save file as TXT or CSV....?? Quote
VVA Posted August 2, 2009 Posted August 2, 2009 My mistake. Load new version from #12. Try again Quote
kassahunabdulaziz Posted September 5, 2009 Posted September 5, 2009 I try to use it but it gives me a massage "Unknown command "COOR". Press F1 for help." What I done is Just change download file format from attachment.php to attachment.lsp then I go to aut0cad 2008 tools menu > load application > load file > close .would you tell me what to do? Quote
Lee Mac Posted September 5, 2009 Posted September 5, 2009 kassahunabdulaziz said: I try to use it but it gives me a massage... Wow, I wish my LISPs would give me a massage... kassahunabdulaziz said: "Unknown command "COOR". Press F1 for help." What I done is Just change download file format from attachment.php to attachment.lsp then I go to aut0cad 2008 tools menu > load application > load file > close .would you tell me what to do? Make sure you have saved the file as .lsp and that the "Save as Type" Box is set to "All Files". Quote
kassahunabdulaziz Posted September 17, 2009 Posted September 17, 2009 Still now I couldn’t use ECoor.lsp .Would anyone help me on general steps to follow Quote
VVA Posted September 18, 2009 Posted September 18, 2009 maybe it will help: How to use the LISP routines in this archive Quote
daffet Posted September 23, 2009 Posted September 23, 2009 Hello, I would like to extract the coordinates of a polyline with an interval of 2 meters between each point. I looked at the COORN code but I'm not really good at programming. Can someone help me? Thank you very much. Quote
