Hi there! I am exploring lisp and dcl at the same time.
I have this DCL as shown below. Whenever the command is done and doing the same command again, values reset (pic2).
I want the values to remain whenever I used the dcl again after I press "Ok" to edit particular inputs instead of typing the whole data again. How could I possibly do that?
pic3.JPG.2652697aab4c7be6d1b24138480271bf.JPGpic4.JPG.97df3f2b9f7b84a8d64def88cee91f2e.JPG
Here is the dcl code I used.
CHECKING : dialog {
          label = "CHECKING";
            : row {
		:boxed_row {
			label = "PARAMETERS";
			: edit_box { key = "a"; label = "Wind Pressure (kPa)"; edit_width = 8;}
			: edit_box {key = "b"; label = "Tributary Width (mm)"; edit_width = 8;}
			: edit_box {key = "c"; label = "Unsupported Length (mm)"; edit_width = 8;}
	    : row {
		:boxed_column {
			label = "SECTION PROPERTIES (ALUMINUM)";
			: edit_box { key = "d"; label = "Moment of Inertia (mm^4)"; edit_width = 8;}
			: edit_box {key = "e"; label = "Area (mm^2)"; edit_width = 8;}
			: edit_box {key = "f"; label = "Extreme Fiber (mm)"; edit_width = 8;}
			: edit_box {key = "g"; label = "Allowable Stress (MPa)"; edit_width = 8;}
		:boxed_column {
			label = "SECTION PROPERTIES (STEEL)";
			: edit_box { key = "h"; label = "Moment of Inertia (mm^4)"; edit_width = 8;}
			: edit_box {key = "i"; label = "Area (mm^2)"; edit_width = 8;}
			: edit_box {key = "j"; label = "Extreme Fiber (mm)"; edit_width = 8;}
			: edit_box {key = "k"; label = "Allowable Stress (MPa)"; edit_width = 8;}
		: button {
                key = "accept";
                label = " &OK ";
                is_default = true;
		mnemonic = "S";
              : button {
                key = "cancel";
                label = " Cancel ";
                is_default = false;
                is_cancel = true;
and here is the lisp code:
(defun saveVars()
	(setq wp(distof(get_tile "a")))
	(setq tw(distof(get_tile "b")))
	(setq L(distof(get_tile "c")))
	(setq Im(distof(get_tile "d")))
	(setq Am(distof(get_tile "e")))
	(setq cm(distof(get_tile "f")))
	(setq Fbm(distof(get_tile "g")))
	(setq Is(distof(get_tile "h")))
	(setq As(distof(get_tile "i")))
	(setq cs(distof(get_tile "j")))
	(setq Fbs(distof(get_tile "k")))
(defun C:CC()
  	(if(not(setq dcl_id (load_dialog "CHECKING.dcl")))
      			(alert "The DCL file could not be loaded!")
      			(exit)
      			(if (not(new_dialog "CHECKING" dcl_id))
       					(alert "CHECKING.DCL file could not be loaded!")
          				(exit)
         				(action_tile "accept" "(saveVars)(done_dialog 2)")
          				(action_tile "cancel" "(done_dialog 1)")
					(setq ddiag(start_dialog))
					(unload_dialog dcl_id)
					(if(= ddiag 1)
            				(princ "\n END")
        		 		(if(= ddiag 2)
							(setq IT(+ Im (* 2.87 Is)))
							(setq moment(/ (* wp tw L L) 8000))
							(setq stress(/ (* moment cm) Im))
							(setq stressratio(/ stress Fbm))
							(setq deflection(/ (* 5 wp tw L L L L) (* 384000 69600 IT)))
							(setq allowdeflection(/ L 175))
							(setq defratio(/ deflection allowdeflection))
							(setq pt1 (getpoint))
							(setq pt2 (getpoint))
							(command "_mtext" pt1 pt2 "\n Actual Bending Stress =" (rtos stress 2 2)
									"\n Allowable Bending Stress =" (rtos Fbm 2 2)
									"\n Stress Ratio =" (rtos stressratio 2 2)
									"\n Actual Deflection =" (rtos deflection 2 2)
									"\n Allowable Deflection =" (rtos allowdeflection 2 2)
									"\n Deflection Ratio =" (rtos defratio 2 2) ""
One more thing. About the mtext output. The output is this. Numerical results always appear on the next line.
and I want the result to be like this with units as text (MPa, mm, etc)
Does someone has a thing about this? Thank you in advance. :)
Another one. The label in dcl with mm^4 and mm^2, how to do superscript without the "^" sign. I can't find it in web. 😮
dcl is very limited so probably not possible , haven't looked into it.
Just a quickfix , haven't got much time at this moment
(defun C:CC  () ; normally you would declare all your variables here
  (if (not(setq dcl_id (load_dialog "CHECKING.dcl")))
    (progn (alert "The DCL file could not be loaded!") (exit))
    (progn (if (not (new_dialog "CHECKING" dcl_id))
             (progn (alert "CHECKING.DCL file could not be loaded!") (exit))
             (progn (cc_set_tiles);;; added this to set your variables
                    (setq ddiag (start_dialog))
                    (if (= ddiag 1)
                      (princ "\n END"))
                    (if (= ddiag 2)
                      (progn (setq IT (+ Im (* 2.87 Is)))
                             (setq moment (/ (* wp tw L L) 8000))
                             (setq stress (/ (* moment cm) Im))
                             (setq stressratio (/ stress Fbm))
                             (setq deflection (/ (* 5 wp tw L L L L) (* 384000 69600 IT)))
                             (setq allowdeflection (/ L 175))
                             (setq defratio (/ deflection allowdeflection))
                             (setq pt1 (getpoint "\nGet 1st point : "))
                             (setq pt2 (getcorner pt1 "\nGet 2nd point : "))
                             (setq msg (strcat "\nActual Bending Stress = "
                                               (rtos stress 2 2)
                                               "\nAllowable Bending Stress = "
                                               (rtos Fbm 2 2)
                                               "\nStress Ratio = "
                                               "\nActual Deflection = "
                                               "\nAllowable Deflection = "
                                               "\nDeflection Ratio = "
                                               (rtos defratio 2 2)))
                             (apply 'vl-cmdf (list "_mtext" pt1 pt2 msg "")))))))))
; tl = tile list / vl = variable list
(defun cc_set_tiles ( / tl vl)
  (mapcar '(lambda (x y)  (set_tile x (if (null (vl-symbol-value y)) "" (vl-princ-to-string (vl-symbol-value y)))))
           (list "a" "b" "c" "d" "e" "f" "g" "h" "i" "j" "k") (list 'wp 'tw 'L 'Im 'Am 'cm 'Fbm 'Is 'As 'cs 'Fbs))
Rlx was faster, anyway heres another way:
(defun C:CC ( / ) ; like Rlx said, normally you would declare all your variables here
  ;; This subfunction will get all the tile's values and will return an association list of (<desired symbol> <tile's value>)
  ;; The list will look like this:
  ;; ((WP "<value_a>") (TW "<value_b>") (L "<value_c>") (IM "<value_d>") (AM "<value_e>") (CM "<value_f>") (FBM "<value_g>") (IS "<value_h>") (AS "<value_i>") (CS "<value_j>") (FBS "<value_k>"))
  (defun SaveVars ()
    (mapcar 'list '(wp tw L Im Am cm Fbm Is As cs Fbs)
      (mapcar '(lambda (x) (distof (get_tile (strcase (vl-symbol-name x) t))))
        '(a b c d e f g h i j k)
  ); defun SaveVars
  ;; (exit) function will interrupt the whole routine, so you don't need nested wrapping of (if <...> (progn <...>))
  (if (not (setq dcl_id (load_dialog "CHECKING.dcl")))
      (exit)
      (exit)
  ;; check if our list is present and set default values for the tiles
  (if *MyList*
    (foreach x (mapcar 'cons '("a" "b" "c" "d" "e" "f" "g" "h" "i" "j" "k") *MyList*)
      (set_tile (car x) (caddr x))
    ); foreach
  ); if
  ;; Normaly (done_dialog 1) stands for "accept" and (done_dialog 0) stands for "cancel"
    (strcat
      ;; All the variables are stored into an association list
      ;; the list looks like this:
      "(setq *MyList* (saveVars))"
      "(done_dialog 1)"
    ); strcat
  ); action_tile
  (action_tile "cancel" "(done_dialog 0)")
  (if (= ddiag 1)
      ;; iterate through our list and assign values to your symbols, its like:
      ;; (setq WP "<value_a>") (setq TW "<value_b>") (setq L "<value_c>") ...
      (foreach x *MyList*
        (apply 'set x)
      ); foreach
      (foreach x *MyList*
        (set (car x) nil)
      ); foreach
    (princ "\nUser cancelled the dialog")
  ); if (= ddiag 1)
); defun
i wrote a utf-8 function for some asian languages, so i'm pretty sure dcl supports unicode 🙂
mm^2 = mm\U+00B2
mm^4 = mm\U+2074
I agree with Grrr that I would rather store a list of values to one variable (*MyList*) than have a flog of variables having a party in my drawing. But just beginning with lisp this might be a little challenging. Nevertheless , why not learn it the right way right away on the highway , hey 🙂
mm^2 = mm\U+00B2
mm^4 = mm\U+2074
Expand
Jip that works just fine! Good to know! thanx!
BTW Op's code has no data (input) checking what so ever but lets give him (or her) a break (for now) :beer:
oh forgot about the last question in Op's first post : you create a mtext , so the shape of your getpoints (I use getpoint + getcorner) determines if your lines are cut short. Just select a wider rectangle... and if its still too short , just click on the just created mtext and drag it... dig it?
Edited by rlx
Yea, its a pain writing too many codes for the variables, when its enough to store them in a list.
Probably everyone was on OP's level, so thats why I tried not to confuse him too much and on purpose avoided using too many mapcars and lambdas.
Noticed that aswell, but I would suggest for OP attempting to shorten and better understand his code and then go for any future improvements/fixes.
So I think that a simple list manipulation and using the foreach function would be a good start for him. :)
mm^4 = mm\U+2074
I didn't knew that one could write quartic unicode character, nice one!
Edited by Grrr
Ah, just remembered (where I went wrong) , while back I tried to work with CHR for some special characters and it did work (for some) but when I ran the same code at home , the result was totally different. So indeed I should have used UTF-8 (if I ever gonna use it, rarely use special characters) But it's always good to know 🙂
Awel, almost weekend , have a nice weekend y'all :beer:
I use UTF-8 only to display the squared symbol or the plus-minus one,
but I define any of them as a list like this '(92 85 43 48 48 66 50) to reconvert it into a string with the vl-list->string function.
A  piece of advise I remember from @Tharwat was that you could just start creating mtext and use the text formatting editor dialog
to populate with custom character symbol(s) and then just investigate that mtext's string content with LISP. :beer:
Thank you very much @Grrr, @rlx and @hanhphuc for the response. I'll try to understand each line you guys did. Greatly appreciated. It's my second time posting here. More to go. lol. BTW, what does OP means? :D
Edited by joemcanciller
well you're either a #HeToo (probably 99%) , a #SheToo (very unlikely) or an #EtToo so to be on the safe side we call you OPerator :-)
  On 10/13/2018 at 7:22 AM, rlx said:
well you're either a #HeToo (probably 99%) , a #SheToo (very unlikely) or an #EtToo so to be on the safe side we call you OPerator 🙂
How complicated!
For years I thought that OP was shorthand for Original Poster, instead of having to type out the Original Poster's name (which also can be very complicated!!) when replying.
  On 10/13/2018 at 7:36 AM, eldon said:
How complicated!
Original Poster will do nicely too :-) , was just having fun :-)
FWIW they're not the same thing - UTF-8 is a particular way of encoding Unicode
post#163 explained :)
  On 10/13/2018 at 7:40 AM, rlx said:
Original Poster will do nicely too 🙂 , was just having fun 🙂
OP.. OPpa gangnam style  🎧🎶
Expand
must admit most of the gangnam style thingy has kinda passed me by , I know of it but I did like to watch the Jayesslee cover :-)
