Siberian Posted October 2, 2018 Share Posted October 2, 2018 Consider a plan view that shows a vertical pipe with one of its ends being at the floor you're viewing. If I want to continue the pipe run I find it difficult to get the pipe command to snap to the correct end. It often snaps to the end not visible in the current view - which is just annoying. I'm also not having much luck using TAB to switch between the two ends. Am I missing some obvious way to do this? Quote Link to comment Share on other sites More sharing options...
lrm Posted October 2, 2018 Share Posted October 2, 2018 Try setting elevation to at least one half the value of the upper end. Working in the top view osnap end will snap to the upper end of the vertical line. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted October 3, 2018 Share Posted October 3, 2018 On 10/2/2018 at 12:19 PM, Siberian said: Consider a plan view that shows a vertical pipe with one of its ends being at the floor you're viewing. If I want to continue the pipe run I find it difficult to get the pipe command to snap to the correct end. It often snaps to the end not visible in the current view - which is just annoying. I'm also not having much luck using TAB to switch between the two ends. Am I missing some obvious way to do this? What do you mean by "correct end"? Which end should Revit "know" is correct? -TZ Quote Link to comment Share on other sites More sharing options...
lrm Posted October 3, 2018 Share Posted October 3, 2018 Oops! I read it as an AutoCAD question. Didn't notice that the OP was a Revit user. Quote Link to comment Share on other sites More sharing options...
Siberian Posted October 3, 2018 Author Share Posted October 3, 2018 40 minutes ago, tzframpton said: What do you mean by "correct end"? Which end should Revit "know" is correct? I'm not saying Revit should know at all, but it does choose one of the ends - so on what basis is the choice done? Quote Link to comment Share on other sites More sharing options...
tzframpton Posted October 3, 2018 Share Posted October 3, 2018 I think it has to do with direction. For connecting to risers in a Plan View with horizontal pipe, I usually use the Trim tool. See if that gives you a better output. -TZ Quote Link to comment Share on other sites More sharing options...
RobDraw Posted October 8, 2018 Share Posted October 8, 2018 When it doesn't snap as desired, people switch to a section or 3D view to ensure proper selection or draw to the point of connections rather than from. 1 Quote Link to comment Share on other sites More sharing options...
