MODIFICATION IN CODE (TO AVOID CASE SENSITIVE IN TEXT SELECTION FROM LISP)
tnvsb
Dear Helpers,
I got a lisp code that can select text elements in entire drawing by user input. But it's not working for case sensitive letters and also not asking for window selection. Please do needful.
(defun C:SWT (/ str ss) ; = Find String(s) by Content
(setq str (getstring "\nYour [full or partial] string content to search for: "))
(if (setq ss (ssget "_X" (list (cons 0 "*TEXT") (cons 1 (strcat "*" str "*")) (cons 410 (getvar 'ctab)))))
(sssetfirst nil ss); select/highlight/grip
); if
); defun
Regards,
T.Brahmanandam.
Edited by tnvsb
MODIFICATION IN CODE (TO ACCEPT CASE SENSITIVE IN TEXT SELECTION FROM LISP)
(defun C:SWT ( / str ss sss i txt ) ; = Find String(s) by Content
  (setq sss (ssadd))
  (if (setq ss (ssget (list (cons 0 "*TEXT") (cons 410 (getvar 'ctab)))))
      (setq txt (ssname ss (setq i (1- i))))
      (if (wcmatch (cdr (assoc 1 (entget txt))) (strcat "*" str "*"))
        (ssadd txt sss)
      ); if
    ); repeat
  ); if
  (if sss
    (sssetfirst nil sss); select/highlight/grip
  ); if
  (princ); quiet exit
); defun
HTH., M.R.
Edited by marko_ribar
