Just opened the DWG, i got no clue what the problem is?
Perhaps your problem is of the scaling in one layout. I think you may be exacerbating the problem by using an imperial units template for a metric drawing.
Unlock your viepwort in layout L2 and reset to a true scale ratio your currently a ta scale ratio of 0.3 which is not a common scale.
Do zoom 1xp this will set it to 1:1000 as a true scale when you plot your title block to a metric A1 sheet
