tnvsb Posted September 28, 2018 Posted September 28, 2018 (edited) Please see attachmemnts for better understanding of my requirement. Dear Helpers, I have a lisp code that can count blocks in different layer. I need a modification like it can give blocks quantities in selected closed polylines which are in different layers. I have two lisp codes now. Can anyone please help me to recode them. Lisp code 1: (LIST THE TOTAL BLOCK COUNT WITH NAMES IN SELECTED AREA) (defun C:BLKLST (/ BLKS CHK I J K L L1 N BNAME ENAME EDATA BLIST BNUM BNAME1 BNAME2 TEMP1 TEMP2 ) (princ "\nUse standard selection methods to ") (setq BLKS (ssget (list (cons 0 "INSERT")))) (setq L (sslength BLKS)) (setq L (- L 1)) (setq I 0) (setq BLIST (list "BLOCK NAMES")) (setq BNUM (list "INSTANCES")) (while (<= I L) (setq ENAME (ssname BLKS I)) (setq EDATA (entget ENAME)) (setq BNAME (assoc 2 EDATA)) (setq BNAME (cdr BNAME)) (setq CHK (member BNAME BLIST)) (if (eq CHK NIL) (setq BLIST (cons BNAME BLIST)) ) ;_ end of if (setq I (+ I 1)) ) ; end while (setq L1 (length BLIST)) (setq L1 (- L1 2)) (setq J 0) (setq N 0) (setq K 0) (while (<= K L1) (setq N 0) (setq BNAME1 (nth K BLIST)) (setq J 0) (while (<= J L) (setq ENAME (ssname BLKS J)) (setq EDATA (entget ENAME)) (setq BNAME2 (assoc 2 EDATA)) (setq BNAME2 (cdr BNAME2)) (if (eq BNAME1 BNAME2) (setq N (+ N 1)) ) ;_ end of if (setq J (+ J 1)) ) ; end while j (setq BNUM (cons N BNUM)) (setq K (+ K 1)) ) ; end while k ;;; Formatting (setq K 0) (princ) (command "TEXTSCR") (princ "\nBlock Name Instance") (while (<= K L1) (setq TEMP1 (nth K BLIST)) (setq TEMP2 (nth (- L1 K) BNUM)) (princ "\n") (princ TEMP1) (princ "\t\t\t") (princ TEMP2) (setq K (+ K 1)) ) ; end while k (princ "\n\nPress the <F2> key to hide the text screen after viewing results... ") (princ) ) ;_ end of defun ;(princ ; "\n Blocklst loaded... Start command by typing BLOCKLST " ;(princ) Lisp code 2: (COUNT SELECTED BLOCKS LAYER WISE) (defun c:LBC (/ en ss ctr bl the_list n) (setq ss (ssget (list (cons 0 "INSERT"))) ctr (sslength ss) ) (repeat ctr (setq ctr (1- ctr) en (entget (ssname ss ctr)) bl (strcat (cdr (assoc 2 en))"/"(cdr (assoc 8 en))) ) (if (setq count (cdr (assoc bl the_list))) (setq the_list (subst (cons bl (1+ count))(cons bl count) the_list)) (setq the_list (cons (cons bl 1) the_list)) ) ) (setq the_list (vl-sort the_list '(lambda (e1 e2)(< (car e1) (car e2))))) (foreach n the_list (princ (strcat "\nBlock/Layer: " (car n) ", count of :" (itoa (cdr n)))) ) ) Thanks, T.Brahmanandam COUNTING BLOCKS WITH ZONE WISE.dwg Edited September 28, 2018 by tnvsb Quote
BIGAL Posted September 28, 2018 Posted September 28, 2018 (edited) This is what I was looking for I am working on a data export of block info so your dwg is perfect for me to test, it crashed so that is good as I need real world test dwg's. I will do some more debugging and find out why, it makes a table of the results. I am looking though at commercial aspect say shareware cheap price etc. I changed your blocks to have attributes and is sort of working, this shows zone 1 but you just select each zone and add to the 1 table you would just add a line in the table Zone number before add next zone the code keeps adding to the table or creates a new one if required. It should have seperated the different watts for a light type and totaled them will re debug code. Edited September 28, 2018 by BIGAL Quote
mostafa badran Posted September 30, 2018 Posted September 30, 2018 Hi,take a look for this Block Counter. Quote
