So, we have a SUE department and they use all sorts of line styles, example: -----CaTV D-----. The issue is that when exporting to a KML/KMZ file using GE Pro, the lines display in GE as solid lines. Going from Microstation to GE, the line styles display just as they do in the dgn.
Anyone know any information about this or a way to resolve it?
Currently, we're going from Acad to DGN to KML/KMZ to get the line styles to display.
Thanks in advance!
Are your line styles using alpha characters as in a font or have you tried making shape files of the characters in a linetype may fix .
Oh if a font which one.
Edited by BIGAL
We are using RomanS as the default font for line styles. I'll try the shape file fix and see what that does.
I'm not seeing this as an option on paths in GE Pro 7.x.  Is MS breaking the lines and/or overlaying masked text at various points?
Do you have a KMZ example from MS that you can post?
