JimB Posted September 21, 2018 Share Posted September 21, 2018 Solution be appreciated. You will be able to see the word "Sowing Room" in model and part of it in Layout. I dont know what ot do... cant see in layout Ive looked at a multitude of options Order ..to front.. above ... TEXTTOFRONT ... and mucked around with a heap of other stuff Nothing working ... any suggestions be appreciated ? File Ive put below Regards, Jim DP01.dwg Quote Link to comment Share on other sites More sharing options...
steven-g Posted September 21, 2018 Share Posted September 21, 2018 Select all your text and give it a Z value of 7500 in the properties palette, that will bring it above the solids making it visible. Or change your visual style to 2D wireframe. 1 Quote Link to comment Share on other sites More sharing options...
JimB Posted September 21, 2018 Author Share Posted September 21, 2018 Yep that worked Steve. Thanks. Whats happening when I do that ... its lifting it above everything? Quote Link to comment Share on other sites More sharing options...
JimB Posted September 21, 2018 Author Share Posted September 21, 2018 I dont unerstand why none of the orders in front or above wouldnt do it Steve? Quote Link to comment Share on other sites More sharing options...
steven-g Posted September 21, 2018 Share Posted September 21, 2018 Yes it's just lifting the text above the solids. Draw order is intended to work for items all on the same level such as hatches, wipeouts and text not for items with different elevations. Quote Link to comment Share on other sites More sharing options...
JimB Posted September 21, 2018 Author Share Posted September 21, 2018 19 minutes ago, steven-g said: Select all your text and give it a Z value of 7500 in the properties palette, that will bring it above the solids making it visible. Or change your visual style to 2D wireframe. 2 minutes ago, steven-g said: Yes it's just lifting the text above the solids. Draw order is intended to work for items all on the same level such as hatches, wipeouts and text not for items with different elevations. Ok ... much appreciate you making contribution. Ill remember well the advice. Quote Link to comment Share on other sites More sharing options...
steven-g Posted September 21, 2018 Share Posted September 21, 2018 Your welcome. Quote Link to comment Share on other sites More sharing options...
