mattador04 Posted September 20, 2018 Posted September 20, 2018 Please see image, as I wish to rotate the CYAN colored family object by 90 degrees. It will not go. I have checked everything that I know to check. You can even see that the work plane is theoretically oriented properly. Thanks, -MR Quote
nod684 Posted October 10, 2018 Posted October 10, 2018 it would help if you can detach and attach the file for others to examine the element thoroughly... Quote
mattador04 Posted October 14, 2018 Author Posted October 14, 2018 Thanks for your response. I really think that this issue has to do with the fact that the cyan object (specialty equipment family, wall based) is associated with a host, and this association is what is preventing the rotate from functioning. Unfortunately I am not authorized to share the file in its entirety (someone else owns it). -MR Quote
