DavidGraham Posted September 20, 2018 Share Posted September 20, 2018 I'm trying to write data to Sheet1 in Excel using a LISP routine. I found the following code to write to Sheet2: (defun pl:excel-ac () (setq OEX (vlax-get-or-create-object "Excel.Application")) ;_Object Excell (setq OWRB (vlax-get-property OEX 'Workbooks)) ;_Object Workbook (setq AWB (vlax-invoke-method OWRB 'Add)) ;_Active Workbook (setq ASH (vlax-get-property AWB "Worksheets")) ;_Active WorkSheet (setq MySheet (vlax-invoke-method ASH 'Add)) ;_Sheet ) I have also found the following code to name a sheet as 'NewSheet' (vl-load-com) (setq excel-app (vlax-create-object "excel.application")) (vlax-put-property excel-app 'Visible :vlax-true) (setq wb-collection (vlax-get excel-app "workbooks")) (setq wb (vlax-invoke-method wb-collection 'Add)) (setq sht (vlax-invoke-method (vlax-get-property excel-app 'Worksheets) 'Add ) ) (vlax-put-property sht 'Name "NewSheet") How do I write into Sheet1? Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted September 20, 2018 Share Posted September 20, 2018 Check out this lisp code. It probably contains everything you need. 1 Quote Link to comment Share on other sites More sharing options...
Grrr Posted September 20, 2018 Share Posted September 20, 2018 (setq ASH (vlax-get-property AWB "Worksheets")) ;_Active WorkSheet The above code comment is false, because you actually obtain the Worksheets collection and not the active worksheet. So instead of including a new Sheet object to the collection.... (setq MySheet (vlax-invoke-method ASH 'Add)) ;_Sheet ...You can try accessing the first sheet (Sheet1) via the 'Item' property (which is 1-based) : (vlax-get-property ASH 'Item 1) Or the item property/method can accept the object's name property as argument (for each object, which is inside of the collection). So: (vlax-get-property ASH 'Item "Sheet1") Usually Item is known as a method, but here (in MS Excel) its used as a property. Quote Link to comment Share on other sites More sharing options...
DavidGraham Posted September 21, 2018 Author Share Posted September 21, 2018 Thanks, I just needed to change the code to get the 1st sheet (Sheet1) then rename it to "Spool". (setq OEX (vlax-get-or-create-object "Excel.Application")) ; Object Excel (setq OWRB (vlax-get-property OEX 'Workbooks)) ; Object Workbook (setq AWB (vlax-invoke-method OWRB 'Add)) ; Active Workbook (setq ASH (vlax-get-property AWB "Worksheets")) ; Active WorkSheet (setq MySheet (vlax-get-property ASH 'Item 1)) ; get 1st sheet (Sheet 1) (vlax-put-property MySheet 'Name "Spool") ; Sheet - Spool Quote Link to comment Share on other sites More sharing options...
