Engr Varsi Posted September 19, 2018 Posted September 19, 2018 Hi, Being new to this forum, I have first tried the search option to look for similar problem which I couldn't. Problem: Panning in Top, Left or any other Orthographic View, shows the hidden or out plane details. Please see in this figure. This is a circle extruded to height of 45ft and I panned in the TOP View to the right This is when I panned it to upper left corner. Desired Output: I just want it to be panned as in true Orthographic Projection. As shown in the figure below. Thanks. Quote
ReMark Posted September 19, 2018 Posted September 19, 2018 (edited) Why are you using panning to obtain the proper view? Why aren't you using viewports? Edited September 19, 2018 by ReMark Quote
Engr Varsi Posted September 19, 2018 Author Posted September 19, 2018 1 minute ago, ReMark said: Why are you using panning to obtain the proper view? Have multiple items on sheet. Due to a lot of reasons. And this is not the case if I make a new drawing and draw 3D on it. May I know what is the problem? Quote
Engr Varsi Posted September 19, 2018 Author Posted September 19, 2018 4 minutes ago, Cad64 said: Turn Perspective off. Thanks @Cad64 Solved Quote
