rkmcswain Posted September 18, 2018 Share Posted September 18, 2018 I'm not sure if this is limited to Civil 3D, or whether it applies to AutoCAD also. I'm starting to find that inside of user's %temp% folder, is a subfolder named "proteinrun", and inside this folder are tons of other folders, and inside each one of those, are more files and folders. On the few that I'm run across, there are thousands of files/folders sitting here, anywhere from 6-8 GB in total size. Ultimately, the files, when you finally drill your way to them, are .PNG files. I traced it back to Autodesk because of this KB article - which says it's related to Inventor, and that these files are deleted once Inventor closes. We are not using Inventor, and the files are not being deleted. I suppose it's possible that the files are not being deleted due to application crashing, but I was wondering if anyone else has run across this bloat? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 19, 2018 Share Posted September 19, 2018 Its 29.5Mb and seems to be created on some sort of random day basis like every couple of days. There is a heap of other junk in there as well TCD????.TMP maybe 3 per day. Even my Autocad temp directory has stuff every day added. c: cd\ cd acadtemp del *.log del *.ac$ DEL *.sv$ del {*.* del *.err attrib etrans*.* -h del etrans*.* Quote Link to comment Share on other sites More sharing options...
steven-g Posted September 19, 2018 Share Posted September 19, 2018 I have it as well, we use Autocad 2018/19 and Revit 2018/19, not Inventor Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted September 19, 2018 Share Posted September 19, 2018 It's not on my system. We only use vanilla AutoCAD, so possible explanations are: * it's a vertical app thing * it's some other app * we have it, only under another name * we haven't yet done whatever triggers it Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted September 19, 2018 Author Share Posted September 19, 2018 I'm afraid to add this to my %temp% folder clean up utility right now since I could run into huge deposits of this bloat, and it would stall the ACAD startup in the process.... I think I'll query the PCs first to get an idea of how widespread and thick this problem is.... Thanks for the info. Quote Link to comment Share on other sites More sharing options...
