calculate area of a specific layer
Hi all!
i need a VBA code for calculating area of a specific layer
i have a code for calculating an area but it just computing the whole objects and polyline in the model space
Your help will be really much appreciated
Best Regards,
Jomer
Edited by jomer
Are you asking for a boundary area of the 1layer , not individual objects ?
If this is the case there are just so many different ways of interpreting the answer depending on the interactivity of the shapes involved.
Thank you for your concern sir
Yes sir, i'm referring to the area of 1 layer, not individual objects
This is the code i get in computing the area but for the whole model space
Public Function GetTotalPolylineArea() As Double
  Dim area As Double
  Dim ent As AcadEntity
  Dim pl As AcadLWPolyline
  For Each ent In ThisDrawing.ModelSpace
    If TypeOf ent Is AcadLWPolyline Then
      Set pl = ent
      area = area + pl.area
    End If
  Next
  GetTotalPolylineArea = area
End Function
Sir i have list of layers in combobox
The problem is how can i get the area of the layer i choose in that combobox
Thank you sir in advance :D
Edited by jomer
  • 4 weeks later...
'Im referring to the area of 1 layer, not individual objects '
Layer as layer doesn't have area, but you can calculate area of elements on layer, but again, not for all. Point, text doesn't have area. Layer is just property of any object, just as collor (entity is word we usualy use)
  • 3 weeks later...
You can identify each polyline through the layer and select it and extract the area.
