Lisp for opening a file in a specified folder
I think I got it!
In the image you posted I can see that your AutoCAD expects a drawing name but the Lisp sends him a "y". I am at home now, but please locate this line:
(command "fileopen" "y" (nth ToOpen DWGlist))
and delete the "y", so that line becomes:
(command "fileopen" (nth ToOpen DWGlist))
My AutoCAD asks the user for a confirmation, that's why I wrote that "y".
  On 9/17/2018 at 7:23 PM, fuccaro said:
I think I got it!
Expand
I dont know why it asked me about enter number of file to open, i enter "1" then it did not open. Here is my log
Edited by vudungcom
The open "Y" is linked to SDI mode if you have only 1 dwg open it will work tested 2018 2019 did not work when I had 3 dwgs open.
If you only want 1 path just change the code so path is till defined remove in my version the listbox code.
Edited by BIGAL
yes, i also tested this but still can not.
This time mine is 2 and i still can not open
Now this one is confusing; sometimes you need that "y" in the command line and sometime that causes the error.
Please enter SDI at the command prompt and tell me returned value
I wish I could stay at your computer. Please put back that "Y" in the "command" function. It should work.
@fuccaro the return value is 0, i put back "y" but not work.
Thank you
