Spot Posted September 10, 2018 Posted September 10, 2018 I currently use an older version of autocadd (2004) and am considering purchasing Rhino. I want to see if Rhino is 1) compatible with my older cadd drawings as well as my clients newer dwg files, 2) if I can import aerials (jpg and tiff files) and work with them as far as scaling and rotating in Rhino, and 3) draw polylines to calclulate areas. Thanks Quote
tzframpton Posted September 10, 2018 Posted September 10, 2018 Does Rhino offer an evaluation period with their software? Can you download it and use it as a trial to test? -TZ Quote
f700es Posted September 10, 2018 Posted September 10, 2018 Rhino does offer a trial period. It also should be able to open at least r2013 dwg files as well as handle raster files. Quote
tzframpton Posted September 10, 2018 Posted September 10, 2018 On 9/10/2018 at 11:47 AM, f700es said: Rhino does offer a trial period. It also should be able to open at least r2013 dwg files as well as handle raster files. Eww, that's a bummer. Quote
f700es Posted September 10, 2018 Posted September 10, 2018 Why, SketchUp can't open current AutoCAD files. Not a real shocker. Must 3rd party apps are usually not compatible with current AutoCAD versions or not all of them. Quote
tzframpton Posted September 10, 2018 Posted September 10, 2018 On 9/10/2018 at 12:38 PM, f700es said: Why, SketchUp can't open current AutoCAD files. Not a real shocker. Must 3rd party apps are usually not compatible with current AutoCAD versions or not all of them. Bummer as is no trial period for their software. I think all software should let you test it out. -TZ Quote
f700es Posted September 10, 2018 Posted September 10, 2018 " Rhino does offer a trial period. " Huh????? It does offer a trial period For 90 days even. Put your glasses on son (I've got mine on) Quote
Cad64 Posted September 10, 2018 Posted September 10, 2018 Not only is the trial period 90 days, which is awesome since most companies only offer a 30 day trial or sometimes even less, but once the trial ends, the program still continues to work. The plug-ins stop working and you can't save your work, but you can continue to learn and play around with the program as long as you want, until you decide to buy. https://www.rhino3d.com/download 1 Quote
tzframpton Posted September 10, 2018 Posted September 10, 2018 Oh man, too early and haven't had my coffee yet! Sorry about that. Quote
f700es Posted September 10, 2018 Posted September 10, 2018 LOL, no worries Tanner. Been there some mornings myself Sean Quote
