Line at angle relative to existing line
Hello forum!!!
I want to draw a line relative to an angle of existing line.
When polar tracking is on Autocad shows a reference line in particular way. Not from existing line as I want. My turn around is, I draw a new line at the same direction as existing and then rotate it in + Or - angle desired.
My question is: Is there a quicker way of doing this?
Thank you
Am I correct in assuming that the existing line, is not always the last line drawn?
Also, are you always drawing the same angles, relative to something, such as 15, 30, 45, etc., or do you need to be able to set that to anything on the fly?
Thanks for reply!
1.Yes. Existing line, is not always the last line drawn.
2.Not always the same angles.
back to you
You may want to look into the UCS command.  You can select the existing line to adjust the X and Y axis directions
Remember to reset the UCS back to it's previous value.  -David
You could also set the snapangle = to the line segment, then add or subtract from that to get the desired angle, and turn ortho on.
Lisp or macros would help set the snapang, and then the final angle.
Try arraypolar followed by as n i 2 a angle
For example: the following will make a non-associative copy at an angle of 30°.
Command: ARRAYPOLAR
Select objects: 1 found
Select objects:
Type = Polar  Associative = Yes
Specify center point of array or [Base point/Axis of rotation]:  <--- pick rotation center
Select grip to edit array or [ASsociative/Base point/Items/Angle between/Fill angle/ROWs/Levels/ROTate items/eXit]<eXit>: as Create associative array [Yes/No] <Yes>: n
Select grip to edit array or [ASsociative/Base point/Items/Angle between/Fill angle/ROWs/Levels/ROTate items/eXit]<eXit>: i
Enter number of items in array or [Expression] <6>: 2
Specify angle between items or [EXpression] <180>: 30
Select grip to edit array or [ASsociative/Base point/Items/Angle between/Fill angle/ROWs/Levels/ROTate items/eXit]<eXit>: x
Without more information as to the exact usage needed, I would just copy the line and then rotate it.
If I understand your question correctly, your best solution may be the Rotate command. You can specify the Copy option once you select the object and the base point. It's one command instead of two and gives you the flexibility of typing in any angle (or using polar tracking if it's on).
Thank you all!!!
I stay with
distance...same direction as existing line and rotate
  • 2 weeks later...
Expand
Also, look into the MOCORO command which allows multiple move, copy, rotate and scale commands without exiting. Doesn't allow rotation or scaling referencing though.
