wimal Posted September 6, 2018 Share Posted September 6, 2018 How can I add a web address to DCL file displaying blue color (To active when pick on it) Quote Link to comment Share on other sites More sharing options...
rlx Posted September 6, 2018 Share Posted September 6, 2018 (edited) 1 hour ago, wimal said: How can I add a web address to DCL file displaying blue color (To active when pick on it) I don't think text tiles in dcl have a color attribute. Only suggestion I would have at this time, make an image_button. Example in my batch app (see couple of posts back , odxb ...) , rlxbatch.lsp (unfinished routine by the way , just so you know). Make sure you have only 1 drawing open and SDI = 0. Now when you load & run rlxbatch in the lower right corner you should see MDI in a gray field. This means autocad is in multi-docci mode but with only one drawing open. If you click on this field (an image button) it should turn green and show the text SDI , meaning autocad is in single mode. Click on it again and autocad switches back to MDI. (ok , you can stop clicking now this is getting embarrassing haha) If you try the same with more than 1 drawing open this button turns red , meaning you can't go back to single mode unless you close all but the current drawing. or put it in a list or edit box but that's only shifting focus , but the color would be white letters on blue If someone has an other or better way , I'm all ears... gr. Rlx Edited September 6, 2018 by rlx 1 Quote Link to comment Share on other sites More sharing options...
