Oscar Posted September 4, 2018 Share Posted September 4, 2018 (edited) I struggle understanding how to scale objects properly. I know how to use the command and all but I don't really see how my co-workers figure out the scale factor. I think they look at the scale on the drawing like a 1/4"= 1' and go by that when I bring in blocks or text. I guess I am looking for someone to point me in the direction of a helpful video or explain it to me like Im 5 haha. Edited September 4, 2018 by Oscar Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted September 4, 2018 Share Posted September 4, 2018 You should draw everything full scale in model space, regardless if you are designing a watch, or a 2 million sq. ft. factory. Then you can "scale" the objects in your viewport when you create your layout. See this for more info. 1 Quote Link to comment Share on other sites More sharing options...
rkent Posted September 4, 2018 Share Posted September 4, 2018 Using your example, you want to determine how many 1/4" are in one 1' or 12". Invert the fraction and multilply, 4/1 X 12 = 48 scale factor. For 1/8" = 1'-0", 8/1 X 12 = 96 scale factor. There are plenty of websites that go over this, many have the math already worked out for you on a PDF file. good luck 1 Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted September 4, 2018 Share Posted September 4, 2018 Not sure if this is applicable to your case, but annotative text and blocks can help you resolve scaling issues. Of course, annotative objects open up their own cans of worms. The nice thing is that you define the size once and assign scales to the object as necessary. 1 Quote Link to comment Share on other sites More sharing options...
Oscar Posted September 4, 2018 Author Share Posted September 4, 2018 9 hours ago, rkmcswain said: You should draw everything full scale in model space, regardless if you are designing a watch, or a 2 million sq. ft. factory. Then you can "scale" the objects in your viewport when you create your layout. See this for more info. Thanks rkmcswain! that video helped alot. 1 Quote Link to comment Share on other sites More sharing options...
