This code works fine for running lisp at a given time.
However, if the computer's schedule changes, it will still work, how can I fix it?
(defun C:Temp (/ ha)
  (setq ha (rtos (getvar "cdate") 2 6))
  (if
    (>= (atof ha) 20180901.091000);Set time
     (alert "\nYour time is over!")
     (command "_.Line");Subrotina
Are you trying to set a check time and if invalid stop working ? This is a common security questions and has been answered a few times here. One way around is to get International time via the internet. have a look at www.lee-mac.com.
  • Confused 1
@BIGAL I do not understand, do you have an example?
