Jim Clayton Posted August 29, 2018 Share Posted August 29, 2018 PrintPDF.lsp Quote Link to comment Share on other sites More sharing options...
Jim Clayton Posted August 29, 2018 Author Share Posted August 29, 2018 Not sure why but everything I typed didn't save. Again, I found the about Lisp. It looks like it will work, but it's wanting to print from the Layout Tab. I prefer Model Space. Can someone take a glance at it and let me know what, if any, changes to make to make this happen? Please and thank you. Quote Link to comment Share on other sites More sharing options...
rlx Posted August 29, 2018 Share Posted August 29, 2018 (edited) (if (= (getvar "tilemode") 0) ;paperspace (command ".-Plot" ;command "Yes" ;detailed "" ;layout name "Dwg To PDF.pc3" ;printername "ISO A1 (279.40 x 431.80 MM)" ;papersize "Millimeters" ;millimeters "Landscape" ;landscape/portrait "No" ;plot upside down "E" ;plotarea (Display/Extends/Layout...) "Fit" ;plotscale "0,0" ;offset OR center "Yes" ;plot with styles "acad.ctb" ;plotstyle name "Yes" ;plot with lineweights "No" ;scale lineweights with scale "No" ;plot paperspace last "No" ;remove hidden lines "No" ;write plot to a file "No" ;save changes to lay-out "Yes" ;proceed with plot ) ; modelspace (command ".-Plot" ;command "Yes" ;detailed "" ;layout name "Dwg To PDF.pc3" ;printername "ISO A1 (279.40 x 431.80 MM)" ;papersize "Millimeters" ;millimeters "Landscape" ;landscape/portrait "No" ;plot upside down "E" ;plotarea (Display/Extents/Limits/View/Window) "Fit" ;plotscale "Center" ;offset "Yes" ;plot with styles "acad.ctb" ;plotstyle name "Yes" ;plot with lineweights "" ;shade plot setting [As displayed/Wireframe/Hidden/Rendered] <as displayed> "No" ;write plot to a file "No" ;save changes to model-tab "Yes" ;proceed with plot ) ) ) Edited August 29, 2018 by rlx Quote Link to comment Share on other sites More sharing options...
maratovich Posted August 30, 2018 Share Posted August 30, 2018 15 hours ago, Jim Clayton said: Not sure why but everything I typed didn't save. Again, I found the about Lisp. It looks like it will work, but it's wanting to print from the Layout Tab. I prefer Model Space. Can someone take a glance at it and let me know what, if any, changes to make to make this happen? Please and thank you. If you have a complex title block or you find it difficult to understand the lisp - attach an example dwg file with your title block. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 30, 2018 Share Posted August 30, 2018 Are you wanting to plot only 1 title block in "Model" or multiple this does make a difference. If you have multiple plot areas but using the one title block you can look at each one get the scale of the title block and plot it to correct sheet size. Quote Link to comment Share on other sites More sharing options...
rlx Posted August 30, 2018 Share Posted August 30, 2018 (edited) OP's code begins with (command "tilemode" "0") This is a command and not a test to obtain the value of tilemode. so the program actively forces autocad to switch to paperspace. This has nothing to do with the complexity of the titleblock. Code I posted only plots whatever value of tilemode. If you want to actively switch to modelspace mode change code to (command "tilemode" "1") But I'm not sure this is the kind of behavier OP wants. Be aware the number of prompts for model and paperspace are different. Edited August 30, 2018 by rlx Quote Link to comment Share on other sites More sharing options...
Jim Clayton Posted September 4, 2018 Author Share Posted September 4, 2018 Apologies for the delay. BigAl: Only wanting 1 Title block and the contents within printed in Model. Rlx: For one reason or another I'm having trouble actually getting the above lisp to perform. Not sure what the issue is. Want to look into it further unfortunately I haven't had much time the past few days. Plan on revisiting it when I get a chance. Quote Link to comment Share on other sites More sharing options...
rlx Posted September 4, 2018 Share Posted September 4, 2018 6 minutes ago, Jim Clayton said: Apologies for the delay. BigAl: Only wanting 1 Title block and the contents within printed in Model. Rlx: For one reason or another I'm having trouble actually getting the above lisp to perform. Not sure what the issue is. Want to look into it further unfortunately I haven't had much time the past few days. Plan on revisiting it when I get a chance. no worries , this site will still be here when you're back 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 5, 2018 Share Posted September 5, 2018 Try this one 1 title block or more it will work, you do need to customise it though to suit your title block. Plot-multi-titles-in-layout.lsp Quote Link to comment Share on other sites More sharing options...
