Jim Clayton Posted August 28, 2018 Posted August 28, 2018 Going to try and explain this with as little confusion as possible. I have a series of drawings. Sometimes 1-10, sometimes 1-100. They all have BOM's. BOM's consist of Item#, QTY, UOM, Description, Material, & Stock Code. I want to extract the UOM, QTY, and Stock Code from all sheets in the series and send them to an excel sheet. The preferred execution method would be to do this from the Excel side, but I'm open to a Lisp or other suggestions. Anyone think they might be able to help? The BOM attributes are laid out per attachment. Would greatly appreciate any guidance on this. Tks. Below link is from a thread that is similar, but in the opposite direction of what I'm trying to do...I'm not trying to extract/change/import. I only want to extract specific attributes and put onto a spreadsheet. Tks. https://www.cadtutor.net/forum/topic/63793-autocad-title-block-from-excel-vba/?tab=comments#comment-525675 BOM-Model.pdf Quote
Jim Clayton Posted August 28, 2018 Author Posted August 28, 2018 Maybe something along these lines, but modified, that would allow me to select an entire range of drawings to extract data from? Public Sub WriteAttributes() Dim oSset As AcadSelectionSet Dim oEnt As AcadEntity Dim oBlkRef As AcadBlockReference Dim oAtt As AcadAttributeReference Dim varAtt As Variant Dim i As Long Dim ftype(1) As Integer Dim fdata(1) As Variant ftype(0) = 0: fdata(0) = "INSERT" ftype(1) = 66: fdata(1) = 1 Dim dxftype As Variant Dim dxfdata As Variant dxftype = ftype dxfdata = fdata '--------------------- Dim xlApp As Object Dim xlBook As Workbook Dim xlSheet As Worksheet Dim lngRow As Long, lngCol As Long '--------------------- On Error Resume Next Set xlApp = GetObject(, "Excel.Application") If Err <> 0 Then Err.Clear Set xlApp = CreateObject("Excel.Application") If Err <> 0 Then MsgBox "Impossible to initialize an Excel.", vbExclamation End End If End If '--------------------- On Error Resume Next Set oSset = ThisDrawing.SelectionSets.Item("$Attribs$") If Err Then Err.Clear Set oSset = ThisDrawing.SelectionSets.Add("$Attribs$") End If On Error GoTo Err_Control oSset.SelectOnScreen dxftype, dxfdata '--------------------- xlApp.Visible = True Set xlBook = xlApp.Workbooks.Add xlBook.Sheets.Add.Name = 1 Set xlSheet = xlBook.Sheets(1) lngRow = 1 xlSheet.Cells(lngRow, 1).Value = "Block Name" xlSheet.Rows(1).Font.Bold = True xlSheet.Rows(1).Font.ColorIndex = 5 '--------------------- lngRow = 2 For Each oEnt In oSset Set oBlkRef = oEnt If oBlkRef.IsDynamicBlock Then xlSheet.Cells(lngRow, 1).Value = oBlkRef.EffectiveName Else xlSheet.Cells(lngRow, 1).Value = oBlkRef.Name End If varAtt = oBlkRef.GetAttributes lngCol = 2 For i = 0 To UBound(varAtt) Set oAtt = varAtt(i) xlSheet.Cells(lngRow, lngCol).Value = oAtt.TagString xlSheet.Cells(lngRow + 1, lngCol).Value = oAtt.TextString lngCol = lngCol + 1 Next i lngRow = lngRow + 2 Next oEnt '-------------------- Dim oRange As Range Set oRange = xlSheet.UsedRange For i = 2 To oRange.Columns.Count xlSheet.Cells(1, i).Value = "Attribue " & CStr(i - 1) Next '-------------------- xlSheet.Columns.HorizontalAlignment = xlHAlignLeft xlSheet.Columns.AutoFit xlBook.SaveAs ThisDrawing.Path & "\Attributes.xls" xlBook.Close '-------------------- xlApp.Application.Quit Set xlApp = Nothing Set xlBook = Nothing Set xlSheet = Nothing '-------------------- MsgBox "Excel file was saved as: " & vbCr & ThisDrawing.Path & "\Attributes.xls" '-------------------- Err_Control: End Sub[code] Quote
BIGAL Posted September 4, 2018 Posted September 4, 2018 I am working on something at the moment very slowly due to other commitments but sounds like what your after a more personalised version of dataextraction. Basically block name & attribute combos, but the number of attributes is a free variable it could be all or the 1st and 3rd etc. it does totals and sorts on the 1st two attributes so can have a "door" with paint colour and handle type as individual counts. Can you post a sample dwg. It may be easier to just create a CSV file then open in excel. There is lots of lisps about getting attributes of blocks and adding them up etc. Do a google. Pretty sure Lee-mac has a block count lisp. Quote
