As per road Width, Need to classification layer-wise
here Closed Road Network Polyline.
 Requirement  :
1.       As per road Width, Need to classification layer-wise with the help of Command Button in single shot within Drawing.
Up to 4 Meter Road Width : Street Road
4  to 10 Meter Road Width : Minor Road
10  to 20 Meter Road Width : Secondary Road
 20 above  Meter Road Width : Major Road
Private Sub CheckPolylineWidth()
Dim pl1 As AcadPolyline
Dim pl2 As AcadPolyline
Dim pt1 As Variant
Dim pt2 As Variant
Dim Dist As Double
' Set the "OSMODE" variable to Perpedicular
ThisDrawing.SerVariable "osmode,128"
' Select the 2 Polylines.
ThisDrawing.Utility.GetEntity pl1, pt1, "Pick the first Poliline."
pl2 = ThisDrawing.Utility.GetEntity pl1,pt2, "Pick the second Polyline to detect the Road Width."
' Check the distance between the 2 points by drawing a line then get the length of the line
Dim ln As AcadLine
Dim wd As Double
Set ln = ThisDrawing.ModelSpace.AddLine(pt1, pt2)
wd = ln.Length
If (wd <= 4) Then
'Set the layer to StreetRoad
pl1.Layer = "StreetRoad"
pl2.Layer = "StreetRoad"
ElseIf (wd > 4 And wd <= 10) Then
'Set the layer to MinorRoad
pl1.Layer = "MinorRoad"
pl2.Layer = "MinorRoad"
ElseIf (wd > 10 And wd <= 20) Then
' Set the layer to SecondaryRoad
pl1.Layer = "SecondaryRoad"
pl2.Layer = "SecondaryRoad"
ElseIf (wd > 20) Then
' Set the layer to MajorRoad
pl1.Layer = "MajorRoad"
pl2.Layer = "MajorRoad"
Else
      MsgBox "Unable to determine the distance.", vbExclamation + vbOKOnly
End If
'Delete the line reference
ln.Delete
End Sub
For Query Manish.dwg
Edited by CADTutor
Adding code to code block
Please use Code Tags.
This looks like VBA. Are you wanting it as LISP?
If can be done by LISP, then provide the LISP.
I asked what you were wanting, you posted in the LISP forum, but the code looks like VBA.
Quick attempt to fix the VBA code:
  Dim pl1 As Object
  Dim pl2 As Object
  Dim pt1 As Variant
  Dim pt2 As Variant
  Dim Dist As Double
 Dim lyrs As AcadLayers
  ThisDrawing.SetVariable "osmode", 128
    If Err <> 0 Then
        Err.Clear
        MsgBox "Program ended.", , "First polyline missed"
        Exit Sub
    End If
RETRY:
    ThisDrawing.Utility.GetEntity pl2, pt2, "Pick the second Polyline to detect the Road Width"
    Layers = Array("StreetRoad", "SecondaryRoad", "MinorRoad", "MajorRoad")
    For Each Item In Layers
     ThisDrawing.Layers.Add (Item)
   Next
  Dim ln As AcadLine
  Dim wd As Double
  wd = ln.Length
  If (wd <= 4) Then
  Else
  End If
  ln.Delete
End Sub
Note that it could be improved alot... but I just don't do VBA
