Sengna Posted August 23, 2018 Posted August 23, 2018 (edited) Hello, Does anyone know how can i set to default Not to have Multi leader text sitting on the line ? i want to be able to set it in the Multi leader setting window, i want to keep it the same each time. see issue on pic. thank you. Note Autocad 2017 Edited August 23, 2018 by Sengna Quote
Dana W Posted August 23, 2018 Posted August 23, 2018 Use the multi-leader style editor to change the structure. Every piece of the leader is alterable. Quote
SLW210 Posted August 24, 2018 Posted August 24, 2018 _mleaderstyle to open the editor or there are buttons in the Ribbon, Home Ribbon>Annotation or Annotation Ribbon>Leaders. You might look in the Help files to run through what everything does. Quote
Sengna Posted August 24, 2018 Author Posted August 24, 2018 i am going through the drop down list on the editor now, the one i am using is spline leader, Annotative: no,..........still can not find the solution yet. Quote
dlanorh Posted August 24, 2018 Posted August 24, 2018 (edited) On 8/24/2018 at 3:10 PM, Sengna said: i am going through the drop down list on the editor now, the one i am using is spline leader, Annotative: no,..........still can not find the solution yet. Expand Scroll down the list and find the "leader connection" section (use darkened scroll bar to left of sections). It's somewhere below "Text" on the "Properties" palette. There should be two drop down boxes for left attachment and right attachment. One or both of these will be set to underline top line or something similar. Change these options to another from the list. Edited August 24, 2018 by dlanorh Quote
Sengna Posted August 24, 2018 Author Posted August 24, 2018 Thank you dlanorh, Got it, i tested each and the one that will remove underline is using "middle of top line" thanks so much everyone. Quote
Dana W Posted August 24, 2018 Posted August 24, 2018 That is your object Properties dialog, not the mleader editor. The Properties dialog only works for the current selection set. The mleader style editor will change every leader in that style all at once. 1 Quote
SLW210 Posted August 27, 2018 Posted August 27, 2018 I guess myself and Dana W wasted time directing you to the appropriate editor for fixing these. On 8/23/2018 at 10:38 PM, Sengna said: i want to be able to set it in the Multi leader setting window, i want to keep it the same each time. 2 Quote
Dana W Posted August 27, 2018 Posted August 27, 2018 On 8/27/2018 at 10:57 AM, SLW210 said: I guess myself and Dana W wasted time directing you to the appropriate editor for fixing these. Is there a way to put ourselves on someone else;s ignore list? Maybe I should post this in the Feedback sub-forum as a suggested enhancement. 1 Quote
Sengna Posted August 27, 2018 Author Posted August 27, 2018 (edited) On 8/24/2018 at 11:47 AM, SLW210 said: _mleaderstyle to open the editor or there are buttons in the Ribbon, Home Ribbon>Annotation or Annotation Ribbon>Leaders. You might look in the Help files to run through what everything does. On 8/27/2018 at 9:29 PM, Dana W said: Is there a way to put ourselves on someone else;s ignore list? Maybe I should post this in the Feedback sub-forum as a suggested enhancement. Hello, Dana and SLW210, greatly appreciated your in put and help me on this, i just got back to my office, i have been out on the job field with 4 different tasks, I will definitely follow you guys suggestion when i get a chance, I didn't mean to ignore any of your post. Hope you guys understand. Thank you so much for all your help, i really do. Edited August 27, 2018 by Sengna Quote
Sengna Posted August 27, 2018 Author Posted August 27, 2018 On 8/27/2018 at 10:57 AM, SLW210 said: I guess myself and Dana W wasted time directing you to the appropriate editor for fixing these. Greatly appreciated your help SLW210, i will spend time looking into this some more, i have been out on the job filed, Thank you so much. Quote
Dana W Posted August 27, 2018 Posted August 27, 2018 On 8/27/2018 at 10:59 PM, Sengna said: Hello, Dana and SLW210, greatly appreciated your in put and help me on this, i just got back to my office, i have been out on the job field with 4 different tasks, I will definitely follow you guys suggestion when i get a chance, I didn't mean to ignore any of your post. Hope you guys understand. Thank you so much for all your help, i really do. Not a problem. Sometimes life gets in the way. Hope you didn't mind the joking around. Quote
Sengna Posted August 28, 2018 Author Posted August 28, 2018 you guys scared me, i thought you guys were mad, thank you 1 Quote
SLW210 Posted August 28, 2018 Posted August 28, 2018 Not mad, just highlighting the correct answer for your problem, nothing wrong with the other solution, but it was a one time fix, you asked for a permanent fix. On 8/23/2018 at 10:38 PM, Sengna said: i want to be able to set it in the Multi leader setting window, i want to keep it the same each time. 1 Quote
Sengna Posted August 28, 2018 Author Posted August 28, 2018 i went in "MODIFY MULITILEADER STYLE" under content tap- Left and Right Attachment: "Middle of top line" these are what i want to set to, now it is set as default so i don't have to do each time. Off the topic: if i want to export all my setting ex: text, leaders, layers as template so that i can use the same format all the time, how can i do that? i appreciate any technique that you guy recommended. Thanks Quote
Dana W Posted August 28, 2018 Posted August 28, 2018 On 8/28/2018 at 7:04 PM, Sengna said: i went in "MODIFY MULITILEADER STYLE" under content tap- Left and Right Attachment: "Middle of top line" these are what i want to set to, now it is set as default so i don't have to do each time. Off the topic: if i want to export all my setting ex: text, leaders, layers as template so that i can use the same format all the time, how can i do that? i appreciate any technique that you guy recommended. Thanks Expand This sort of change lives in the drawing individually. If you want to make it permanent for all new drawings, set up a template drawing with this mleader style in it and start all your new drawings from the template. You can also simply copy one of the multi-leaders of this style to another drawing using the clipboard and it will live in that drawing too. BUT the new leader style MUST have a unique name first. If it is copied to another drawing and there is already a style named the same in there already, the existing style will override your new one and it will remain unchanged in the drawing you copied to, just like a block definition. 1 Quote
Sengna Posted September 5, 2018 Author Posted September 5, 2018 OK, i will give that a tried. Thank you Dana Quote
