hello, sometimes ago I was looking for a particular lisp to copy texts...in the end I found the very useful TTC lisp here
https://www.cadtutor.net/forum/showthread.php?18016-Lisp-for-Coping-a-text-to-another-like-match-properties (strangely, the link no longer works)
The lisp allows to select the copy of the text in Multiple or Pair-wise mode, but I would like to split it into two lisps, one for the multiple mode and one for the pair-wise mode.
Can you please help me?
Thank you in advance
ttc.lsp
Cool script.  I made two commands
Command TTCP for single paste
Command TTCM for multiple paste
	;;;;Realization {Smirnoff}
;;; TTC - Text to Text copy. Copy text from DIMENSION, TEXT,
;;;MTEXT, ATTRIB, ATTDEF, ACAD_TABLE to one
	;; PAIR WISE
(defun c:ttcp ( / )
  (ttc "Pair-wise")
	;; MULTIPLE
(defun c:ttcm ( / )
  (ttc "Multiple")
	(defun ttc (mymode / actDoc vlaObj sObj sText curObj oldForm
        oType oldMode conFlag errFlag *error*)
  (vl-load-com)
      (setq actDoc(vla-get-ActiveDocument
        (vlax-get-acad-object)))
      (vla-StartUndoMark actDoc)
  (defun TTC_Paste(pasteStr / nslLst vlaObj hitPt
                   hitRes Row Column)
    (setq errFlag nil)
    (if
     (setq nslLst(nentsel "\nPaste text >"))
  (cond
     (and
       (= 4(length nslLst))
       (= "DIMENSION"(cdr(assoc 0(entget(car(last nslLst))))))
       ); end and
     (setq vlaObj
      (vlax-ename->vla-object
        (cdr(assoc -1(entget(car(last nslLst)))))))
     (if
       (vl-catch-all-error-p
         (vl-catch-all-apply
     'vla-put-TextOverride(list vlaObj pasteStr)))
         (princ "\n Can't paste. Object may be on locked layer. ")
         (setq errFlag T)
         ); end progn
       ); end if
     ); end condition #1
     (and
       (= "ACAD_TABLE"(cdr(assoc 0(entget(car(last nslLst))))))
       ); end and
     (setq vlaObj
     hitPt(vlax-3D-Point(trans(cadr nslLst)1 0))
     hitRes(vla-HitTest vlaObj hitPt
        (vlax-3D-Point '(0.0 0.0 1.0)) 'Row 'Column)
           ); end setq
     (if(= :vlax-true hitRes)
         (if
       (vl-catch-all-apply
         'vla-SetText(list vlaObj Row Column pasteStr)))
       (setq errFlag T)
       ); end progn
     ); end if
         ); end progn
       ); end if
     ); end condition # 2
     (and
       (= "INSERT"(cdr(assoc 0(entget(car(last nslLst))))))
       ); end and
     (princ "\nCan't paste to block's DText or MText. Select Attribute ")
     (setq errFlag T)
     ); end condition #3
     (and
       (= 2(length nslLst))
         (member(cdr(assoc 0(entget(car nslLst))))
           '("TEXT" "MTEXT" "ATTRIB" "ATTDEF"))
       ); end and
     (setq vlaObj
      (vlax-ename->vla-object(car nslLst)))
        (if
       (vl-catch-all-apply
         'vla-put-TextString(list vlaObj pasteStr)))
       (princ "\nError. Can't pase text. ")
      (setq errFlag T)
      ); end progn
     ); end if
     ); end condition #4
    (T
     (princ "\nCan't paste. Invalid object. ")
     (setq errFlag T)
     ); end condition #5
    ); end cond
             T
      ); end progn
            nil
           ); end if
    ); end of TTC_Paste
	    (defun TTC_MText_Clear(Mtext / Text Str)
    (setq Text "")
    (while(/= Mtext "")
      (cond
  ((wcmatch
     (strcase
       (setq Str
        (substr Mtext 1 2)))
   (setq Mtext(substr Mtext 3)
         Text(strcat Text Str)
   ); end setq
  ); end condition #1
  ((wcmatch(substr Mtext 1 1) "[{}]")
    (setq Mtext
     (substr Mtext 2))
  ); end condition #2
   (and
   (wcmatch
     (strcase
       (substr Mtext 1 2)) "\\P")
   (/=(substr Mtext 3 1) " ")
    ); end and
         (setq Mtext (substr Mtext 3)
               Text (strcat Text " ")
         ); end setq
   ); end condition #3
  ((wcmatch
     (strcase
       (substr Mtext 1 2)) "\\[LOP]")
    (setq Mtext(substr Mtext 3))
  ); end condition #4
  ((wcmatch
     (strcase
       (substr Mtext 1 2)) "\\[ACFHQTW]")
    (setq Mtext
     (substr Mtext
       (+ 2
          (vl-string-search ";" Mtext))))
  ); end condition #5
  ((wcmatch
     (strcase (substr Mtext 1 2)) "\\S")
    (setq Str(substr Mtext 3 (- (vl-string-search ";" Mtext) 2))
          Text(strcat Text (vl-string-translate "#^\\" " " Str))
          Mtext(substr Mtext (+ 4 (strlen Str)))
   ); end setq
   (print Str)
  ); end condition #6
  (T
   (setq Text(strcat Text(substr Mtext 1 1))
         Mtext (substr Mtext 2)
  ); end condition #7
      ); end cond
    ); end while
  Text
); end of TTC_MText_Clear
	  (defun TTC_Copy (/ sObj sText tType actDoc)
   (if
    (and
     (setq sObj(car(nentsel "\nCopy text... ")))
     (member(setq tType(cdr(assoc 0(entget sObj))))
     ); end and
        (vlax-get-Acad-object))
      sText(vla-get-TextString
       (vlax-ename->vla-object sObj))
      ); end setq
      (if(= tType "MTEXT")
  (setq sText(TTC_MText_Clear sText))
  ); end if
      ); end progn
    ); end if
    sText
    ); end of TTC_Copy
  (defun CCT_Str_Echo(paseStr / comStr)
    (if(< 20(strlen paseStr))
      (setq comStr
       (strcat
         (substr paseStr 1 17)"..."))
      (setq comStr paseStr)
      ); end if
    (princ
      (strcat "\nText = \"" comStr "\""))
    ); end of CCT_Str_Echo
    (defun *error*(msg)
    (vla-EndUndoMark
    (princ "\nQuit TTC")
    ); end of *error*
    (if(not ttc:Mode)(setq ttc:Mode "Multiple"))
    (initget "Multiple Pair-wise")
    (setq
      oldMode ttc:Mode
      ;; ttc:Mode (getkword (strcat "\nSpecify mode [Multiple/Pair-wise] <" ttc:Mode ">: "))
      ttc:Mode mymode
      conFlag T
      paseStr ""
    ); end setq
    (if(null ttc:Mode)(setq ttc:Mode oldMode))
    (if(= ttc:Mode "Multiple")
  (if(and(setq paseStr(TTC_Copy))conFlag)
    (CCT_Str_Echo paseStr)
    (while(setq conFlag(TTC_Paste paseStr))T
      ); end while
    ); end progn
    ); end if
  ); end progn
  (while
    (and conFlag paseStr)
    (if(and paseStr conFlag)
    (setq errFlag T)
    (while errFlag
         );end while
       ); end progn
      ); end if
    ); end while
  ); end progn
      ); end if
   (vla-EndUndoMark actDoc)
  ); end c:ttc
(princ "\n\t TTC - Text to Text copy. Copy text from DIMENSION, TEXT, MTEXT, ATTRIB, ATTDEF, ACAD_TABLE to one")
Instead of this line that asks for user input:
I gave a parameter mymode to the function ttc.  I haven't thoroughly looked at the rest of the script
Edited by Emmanuel Delay
I'll try it in a week! I answer you to thank you!
  • 2 weeks later...
  • 4 years later...
Hello, I have another problem about this lisp...it doesn't copy from and on miltileader.
Is it possible integrate this object?
Is this the part of lisp to change?
Did you try it and what happened - add "MULTILEADER" to the list
-EDIT-
I think you also need to change this line:
to:
            (or
              (= "MULTILEADER"(cdr(assoc 0(entget(car(last nslLst))))))
I'll let Emmanuel confirm this
Edited by Steven P
You might also look at Lee Macs CopyText function, if you look at it, can have your functions ttcp and ttcm to run the LISP,  then pass a flag to his main functions to do the while loop or not,  I think he covers most things with his LISPs
-EDIT-
to:
            (or
It works! thank you very much!
